ddtabopts | Group Proc |
display(arg, n) | Specify the data to display in each table row. arg can be “first”, “last” or “year”. “first” or “last” will display annual totals, plus the first, or last, n observations in each row. “year” will display observations for n years of data per row. |
firstfreq(freq) | Sets the frequency for the first column grouping: freq can be “n”(native), “a”(annual), “q”(quarterly), “m”(monthly). |
secfreq(freq) | Sets the frequency for the second column grouping: freq can be “none” (none), “n”(native), “a”(annual), “q”(quarterly), “m”(monthly). |
nalabel(“arg”) | Sets the label for NA values to arg. |
+/-displayname | Use display names as default labels. |
transform(row, trans) | Set the transformation method for row row. trans can be: “l”(level), “d”(1 period diff), “yd”(year difference), “pc”(1 period % change), “pca”(1 period % chg-AR), “pcy”(year % chg). |
freqconv(row, conv) | Set the frequency conversion method for the specified row. conv can be “avgtran” (avg then transform), “tranavg” (transform then avg), “sumtran” (sum then transform), “first” (first period), “last”(last period). |
format(fmt= new_format, units=new_units, prefix=” “, suffix=” “, +/-thousand, +/-comma, +/-parens) | Assign a custom prefix/suffix to the number, add a separator (comma or point) to denote thousands, replace a comma with a decimal point, or bracket negative numbers with parenthesis: fmt can be: “f[.prec]”(fixed decimal), “c[.prec]”(fixed characters), “auto”, “serformat”(series format). units can be: “N”(native), “P”(percent), “T”(thousands), “M”(millions), “B”(billions), “TR”(trillions) |
colheader(+/-b, +/- i) | Sets column headers to bold or italic style. |
rowheader(+/-b, +/- i) | Sets row headers to bold or italic style. |
fillcolor(arg) | Set the table row background color to that specified by arg. arg may be one of the predefined color keywords, or it may be specified using individual red-green-blue (RGB) components using the “@RGB” or “@HEX” functions. The arguments to the @RGB function are a set of three integers from 0 to 255, representing the RGB values of the color. The arguments to the “@HEX” function are a set of six characters representing the RGB values of the color in hexadecimal. Each two character set represents a red, green or blue component in the range '00' to 'FF'. For a description of the available color keywords see
“Color definitions”. |
altfillcolor(colorspec) | Set the table alternate row background color to colorspec. colorspec may consist of an @rgb(r,g,b) or @hex specification or it may be the name of a basic color such as “white”, “blue”, “red”, “black”, etc. |
font(row, “name”, size, +/–b, +/–I, +/–s, +/–u) | Sets the font, size and style. name should be the quoted name of the font, size should be an integer size value. You may use +b, +i, +s or +u to set bold, italic, strikeout or underline respectively. |
yrformat(arg) | Sets the date format for year date labels. arg may be “YYYY” (4-digit years) or “YY” (2 digit years). |
qtrformat(arg) | Sets the date format for quarterly date labels. arg may be “QR” (upper-case Roman numerals), “qr” (lower-case Roman numerals), “[Q]Q” (“Q” followed by the quarter number), “Q” (quarter number), “Mon” (3 letter month abbreviation for first month in quarter), “Month” (full month name for first month in quarter). |
monformat(arg) | Sets the date format for monthly date labels. arg may be “[M]mm” (“M” followed by month number), “mm” (month number), “MM” (month number with preceding zero), “[M]MM” (“M” followed by month number with preceding zero) “Mon” (3 letter month abbreviation), “Month” (full month name), “M” (upper-case first letter of month name), or “m” (lower-case first letter of month name). |
qtryrformat(arg) | Sets the joint date format for quarter and year. Only applicable if “Display(first)” or “Display(last)” is used. arg may be: “YYYY[q]Q]”, “YYYY[Q]Q”, “YYYY:Q”, “YY[q]Q”, “YY[Q]Q”, “YY:Q”, “YYYY QR”, “YYYYqr”, “YYYY qr”, “YY QR”, “YYqr”, “YY qr”, “Mon YYYY”, “Mon YY”, or “Month YYYY”. See description of “yrformat” and “qtrformat” above for details. |
monyrformat(arg) | Sets the joint date format for month and year. Only applicable if “Display(first)” or “Display(last)” is used. arg may be: “YYYY[m]mm]”, “YYYY[M]mm”, “YYYY[m]MM”, “YYYY:M”, “YY[m]mm”, “YY[M]mm”, “YY[m]MM”, “YY:mm”, “YY:MM”, “Mon YYYY”, “Mon YY”, “Month YYYY”, “Month YY”, “YYMon”, or “YY-Mon”. See description of “yrformat” and “monformat” above for details on each. |
+/– endperiod | Use end of period date labels. |
blue | @rgb(0, 0, 255) | @hex(0000ff) |
red | @rgb(255, 0, 0) | @hex(ff0000) |
ltred | @rgb(255, 168, 168) | @hex(ffa8a8) |
green | @rgb(0, 128, 0) | @hex(008000) |
black | @rgb(0, 0, 0) | @hex(000000) |
white | @rgb(255, 255, 255) | @hex(ffffff) |
purple | @rgb(128, 0, 128) | @hex(800080) |
orange | @rgb(255, 128, 0) | @hex(ff8000) |
yellow | @rgb(255, 255, 0) | @hex(ffff00) |
gray | @rgb(128, 128, 128) | @hex(808080) |
ltgray | @rgb(192, 192, 192) | @hex(c0c0c0) |
