User’s Guide : Panel and Pooled Data : Pooled Time Series, Cross-Section Data : Working with Pooled Data
Generating Pooled Data
Examining Your Data
Examining Unstacked Data
Examining Stacked Data
Calculating Descriptive Statistics
Computing Unit Root Tests
Performing Cointegration Tests
Making a Group of Pool Series
Making Period Stats
Making a System
Deleting/Storing/Fetching Pool Data
Exporting Pooled Data
The underlying series for each cross-section member are ordinary series, so all of the EViews tools for working with the individual cross-section series are available. In addition, EViews provides you with a number of specialized tools which allow you to work with your pool data. Using EViews, you can perform, in a single step, similar operations on all the series corresponding to a particular pooled variable.
You can generate or modify pool series using the pool series genr procedure. Click on PoolGenr on the pool toolbar and enter a formula as you would for a regular genr, using pool series names as appropriate. Using our example from above, entering:
ratio? = g?/g_usa
is equivalent to entering the following four commands:
ratio_usa = g_usa/g_usa
ratio_uk = g_uk/g_usa
ratio_jpn = g_jpn/g_usa
ratio_kor = g_kor/g_usa
Generation of a pool series applies the formula you supply using an implicit loop across cross-section identifiers, creating or modifying one or more series as appropriate.
You may use pool and ordinary genr together to generate new pool variables. For example, to create a dummy variable that is equal to 1 for the US and 0 for all other countries, first select PoolGenr and enter:
dum? = 0
to initialize all four of the dummy variable series to 0. Then, to set the US values to 1, select Quick/Generate Series… from the main menu, and enter:
dum_usa = 1
It is worth pointing out that a superior method of creating this pool series is to use @GROUP to define a group called US containing only the “_USA” identifier (see “Group Definitions”), then to use the @INGRP function:
dum? = @ingrp(us)
to generate and implicitly refer to the four series (see “Pool Series”).
To modify a set of series using a pool, select PoolGenr, and enter the new pool series expression:
dum? = dum? * (g? > c?)
It is worth the reminder that the method used by the pool genr is to perform an implicit loop across the cross-section identifiers. This implicit loop may be exploited in various ways, for example, to perform calculations across cross-sectional units in a given period. Suppose, we have an ordinary series SUM which is initialized to zero. The pool genr expression:
sum = sum + c?
is equivalent to the following four ordinary genr statements:
sum = sum + c_usa
sum = sum + c_uk
sum = sum + c_jpn
sum = sum + c_kor
Bear in mind that this example is provided merely to illustrate the notion of implicit looping, since EViews provides built-in features to compute period-specific statistics.
Examining Your Data
Pool workfiles provide you with the flexibility to examine cross-section specific series as individual time series or as part of a larger set of series.
Simply open an individual series and work with it using the standard tools available for examining a series object. Or create a group of series and work with the tools for a group object. One convenient way to create groups of series is to use tools for creating groups out of pool and ordinary series; another is to use wildcards expressions in forming the group.
As demonstrated in “Stacked Data”, you may use your pool object to view your data in stacked spreadsheet form. Select View/Spreadsheet View…, and list the series you wish to display. The names can include both ordinary and pool series names. Click on the Order +/– button to toggle between stacking your observations by cross-section and by date.
We emphasize that stacking your data only provides an alternative view of the data, and does not change the structure of the individual series in your workfile. Stacking data is not necessary for any of the data management or estimation procedures described below.
EViews provides convenient built-in features for computing various descriptive statistics for pool series using a pool object. To display the Pool Descriptive Statistics dialog, select View/Descriptive Statistics… from the pool toolbar.
In the edit box, you should list the ordinary and pooled series for which you want to compute the descriptive statistics. EViews will compute the mean, median, minimum, maximum, standard deviation, skewness, kurtosis, and the Jarque-Bera statistic for these series.
First, you should choose between the three sample options on the right of the dialog:
Individual: uses the maximum number of observations available. If an observation on a variable is available for a particular cross-section, it is used in computation.
Common: uses an observation only if data on the variable are available for all cross-sections in the same period. This method is equivalent to performing listwise exclusion by variable, then cross-sectional casewise exclusion within each variable.
Balanced: includes observations when data on all variables in the list are available for all cross-sections in the same period. The balanced option performs casewise exclusion by both variable and cross-section.
Next, you should choose the computational method corresponding to one of the four data structures:
Stacked data: display statistics for each variable in the list, computed over all cross-sections and periods. These are the descriptive statistics that you would get if you ignored the pooled nature of the data, stacked the data, and computed descriptive statistics.
Stacked – means removed: compute statistics for each variable in the list after removing the cross-sectional means, taken over all cross-sections and periods.
Cross-section specific: show the descriptive statistics for each cross-sectional variable, computed across all periods. These are the descriptive statistics derived by computing statistics for the individual series.
Time period specific: compute period-specific statistics. For each period, compute the statistic using data on the variable from all the cross-sectional units in the pool.
Click on OK, and EViews will display a pool view containing tabular output with the requested statistics. If you select Stacked data or Stacked - means removed, the view will show a single column containing the descriptive statistics for each ordinary and pool series in the list, computed from the stacked data. If you select Cross-section specific, EViews will show a single column for each ordinary series, and multiple columns for each pool series. If you select Time period specific, the view will show a single column for each ordinary or pool series statistic, with each row of the column corresponding to a period in the workfile. Note that there will be a separate column for each statistic computed for an ordinary or pool series; a column for the mean, a column for the variance, etc.
You should be aware that the latter two methods may produce a great deal of output. Cross-section specific computation generates a set of statistics for each pool series/cross-section combination. If you ask for statistics for three pool series and there are 20 cross-sections in your pool, EViews will display 60 columns of descriptive statistics. For time period specific computation, EViews computes a set of statistics for each date/series combination. If you have a sample with 100 periods and you provide a list of three pool series, EViews will compute and display a view with columns corresponding to 3 sets of statistics, each of which contains values for 100 periods.
If you wish to compute period-specific statistics, you may save the results in series objects. See “Making Period Stats”.
EViews provides convenient tools for computing multiple-series unit root tests for pooled data using a pool object. You may use the pool to compute independent cross-section tests from Levin, Lin and Chu (2002), Breitung (2000), Im, Pesaran and Shin (2003), Fisher-type tests using ADF and PP tests—Maddala and Wu (1999) and Choi (2001), and Hadri (2000), or you may compute dependent cross-sections tests from Bai and Ng’s (2004) Panel Analysis of Nonstationarity in Idiosyncratic and Common Components (PANIC), and Pesaran’s (2007) Cross-sectionally Augmented IPS (CIPS).
To compute the unit root test, select View/Unit Root Test... from the menu of a pool object.
Enter the name of an ordinary or pool series in the topmost edit field, then specify the remaining settings in the dialog.
These tests, along with the settings in the dialog, are described in considerable detail in “Cross-sectionally Independent Panel Unit Root Testing”.
Panel cointegration tests are available as a view of a group in a panel workfile or for a group of pooled series defined using a pool object. EViews allows you to conduct several different tests: Pedroni (1999, 2004), Kao (1999) and Fisher-type test using Johansen’s test methodology (Maddala and Wu, 1999).
To compute the panel cointegration test for pooled data, select Views/Cointegration Test… from the menu of a pool object. Enter the names of at least two pool series or a combination of at least two pool and ordinary series in the topmost Variables field, then specify the rest of the options.
The remaining options are identical to those encountered when performing panel cointegration testing using a group in a panel-structured workfile. For details, see “References”.
In this example, specify two pool variables “IVM?” and “MM?” and one ordinary variable “X”, so that EViews tests for cointegration between the pool series IVM? against pool series MM? and the stacked common series X.
If you click on Proc/Make Group… and enter the names of ordinary and pool series. EViews will use the pool definitions to create an untitled group object containing the specified series. This procedure is useful when you wish to work with a set of pool series using the tools provided for groups.
Suppose, for example, that you wish to compute the covariance matrix for the C? series. Simply open the Make Group dialog, and enter the pool series name “C?”. EViews will create a group containing the set of cross-section specific series, with names beginning with “C” and ending with a cross-section identifier.
Then, in the new group object, you may select View/Covariance Analysis... to compute the covariance matrix of the series in the group. EViews will perform the analysis using all of the individual series in the group.
Making Period Stats
To save period-specific statistics in series in the workfile, select Proc/Make Period Stats Series… from the pool window, and fill out the dialog.
In the edit window, list the series for which you wish to calculate period-statistics. Next, select the particular statistics you wish to compute, and choose a sample option.
EViews will save your statistics in new series and will open an untitled group window to display the results. The series will be named automatically using the base name followed by the name of the statistic (MEAN, MED, VAR, SD, OBS, SKEW, KURT, JARQ, MAX, MIN). In this example, EViews will save the statistics using the names CMEAN, GMEAN, CVAR, GVAR, CMAX, GMAX, CMIN, and GMIN.
Making a System
Suppose that you wish to estimate a complex specification that cannot easily be estimated using the built-in features of the pool object. For example, you may wish to estimate a pooled equation imposing arbitrary coefficient restrictions, or using specialized GMM techniques that are not available in pooled estimation.
In these circumstances, you may use the pool to create a system object using both common and cross-section specific coefficients, AR terms, and instruments. The resulting system object may then be further customized, and estimated using all of the techniques available for system estimation.
Select Proc/Make System… and fill out the dialog. You may enter the dependent variable, common and cross-section specific variables, and use the checkbox to allow for cross-sectional fixed effects. You may also enter a list of common and cross-section specific instrumental variables, and instruct EViews to add lagged dependent and independent regressors as instruments in models with AR specifications.
When you click on OK, EViews will take your specification and create a new system object containing a single equation for each cross-section, using the specification provided.
Pools may be used to delete, store, or fetch sets of series. Simply select Proc/Delete pool series…, Proc/Store pool series (DB)…, or Proc/Fetch pool series (DB)… as appropriate, and enter the ordinary and pool series names of interest.
If, for example, you instruct EViews to delete the pool series C?, EViews will loop through all of the cross-section identifiers and delete all series whose names begin with the letter “C” and end with the cross-section identifier.
You can export your data into a disk file, or into a new workfile or workfile page, by reversing one of the procedures described above for data input.
To write pooled data in stacked form into an ASCII text, Excel, or Lotus worksheet file, first open the pool object, then from the pool menu, select Proc/Export Pool data (ASCII, .XLS, .WK?)…. Note that in order to access the pool specific export tools, you must select this procedure from the pool menu, not from the workfile menu.
EViews will first open a file dialog prompting you to specify a file name and type. If you provide a new name, EViews will create the file; otherwise it will prompt you to overwrite the existing file.
Once you have specified your file, a pool write dialog will be displayed. Here we see the Excel Spreadsheet Export dialog. Specify the format of your data, including whether to write series in columns or in rows, and whether to stack by cross-section or by period. Then list the ordinary series, groups, and pool series to be written to the file, the sample of observations to be written, and select any export options. When you click on OK, EViews will write the specified file.
Since EViews allows you to both read and write data that are unstacked, stacked by cross-section, or stacked by date, you may use the pool import and export procedures to restructure your data in accordance with your needs.
Alternatively, you may use the workfile reshaping tools to stack the pooled data in a new workfile page. From the main workfile menu, select Proc/Reshape Current Page/Stack in New Page... to open the Workfile Stack dialog, and enter the name of a pool object in the top edit field, and the names of the ordinary series, groups, and pool series to be stacked in the second edit field.
The Order of obs option allows you to order the data in Stacked form (stacking the data by series, which orders by cross-section), or in Interleaved format (stacked the data by interleaving series, which orders the data by period or date).
The default naming rule for series in the destination is to use the base name. For example, if you stack the pool series “SALES?” and the individual series GENDER, the corresponding stacked series will, by default, be named “SALES”, and “GENDER”. If use of the default naming convention will create problems in the destination workfile, you should use the Name for stacked series field to specify an alternative. If, for example, you enter “_NEW”, the target names will be formed by taking the base name, and appending the additional text, as in “SALES_NEW” and “GENDER_NEW”.
See “Stacking a Workfile” for a more detailed discussion of the workfile stacking procedure.
