Pool
Pooled time series, cross-section object. Used when working with data with both time series and cross-section structure.
Pool Declaration
    pool	declare pool object.
 To declare a pool object, use the pool keyword, followed by a pool name, and optionally, a list of pool members. Pool members are short text identifiers for the cross section units:
pool mypool
pool g7 _can _fr _ger _ita _jpn _us _uk
Pool Methods
    ls	estimate linear regression models including cross-section weighted least squares, and fixed and random effects models.
    tsls	linear two-stage least squares (TSLS) regression models.
 Pool Views
    cellipse	Confidence ellipses for coefficient restrictions.
    coefcov	coefficient covariance matrix.
    coint	Johansen’s cointegration test.
    describe	calculate pool descriptive statistics.
    fixedtest	test significance of estimates of fixed effects.
    label	label information for the pool object.
    output	table of estimation results.
    ranhaus	Hausman test for correlation between random effects and regressors.
    resids	table or graph of residuals for each pool member.
    results	table of estimation results.
    sheet	spreadsheet view of series in pool.
    testadd	likelihood ratio test for adding variables to pool equation.
    testdrop	likelihood ratio test for dropping variables from pool equation.
    uroot	unit root test on a pool series.
    uroot2	dependent (second generation panel) unit root tests on a pool series .
    wald	Wald coefficient restriction test.
 Pool Procs
    add	add cross section members to pool.
    clearhist	clear the contents of the history attribute.
    copy	creates a copy of the pool.
    define	define cross section identifiers.
    drop	drop cross section members from pool.
    fetch	fetch series into workfile using a pool.
    genr	generate pool series using the “?”.
    makegroup	create a group of series from a pool.
    makemodel	creates a model object from the estimated pool.
    makeresids	make series containing residuals from pool.
    makesystem	creates a system object from the pool for other estimation methods.
    olepush	push updates to OLE linked objects in open applications.
    read	import pool data from disk.
    setattr	set the value of an object attribute.
    store	store pool series in database/bank files.
    write	export pool data to disk.
 Pool Data Members
String Values
@attr("arg")	string containing the value of the arg attribute, where the argument is specified as a quoted string.
@command	full command line form of the estimation command. Note this is a combination of @method, @options and @spec.
@crossids	space delimited list of the Pool identifiers.
@crossidsest	space delimited list of the Pool identifiers used in estimation.
@description	string containing the Pool object’s description (if available).
@detailedtype	returns a string with the object type: “POOL”.
@displayname	returns the Pool’s display name. If the Pool has no display name set, the name is returned.
@idname(i)	i-th cross-section identifier.
@idnameest(i)	i-th cross-section identifier for estimated equation.
@method	command line form of estimation method (“LS”, “TSLS”, etc....).
@name	returns the Pool’s name.
@options	command line form of pool estimation options.
@remarks	string containing the pool object’s remarks (if available).
@smpl	description of sample used for estimation.
@spec	original Pool estimation specification.
@type	returns a string with the object type: “POOL”.
@updatetime	returns a string representation of the time and date at which the Pool was last updated.
Scalar Values
@aic	Akaike information criterion.
@coefcov(i,j) 	covariance of coefficients i and j.
@coefs(i)	coefficient i.
@dw	Durbin-Watson statistic.
@effects(i)	estimated fixed or random effect for the i-th cross-section member (only for fixed or random effects).
@f	F-statistic.
@logl	log likelihood.
@meandep	mean of the dependent variable.
@ncoef	total number of estimated coefficients.
@ncross	total number of cross sectional units.
@ncrossest	number of cross sectional units in last estimated pool equation.
@npers	number of workfile periods used in estimation of the pool equation.
@r2	R-squared statistic.
@rbar2	adjusted R-squared statistic.
@regobs	total number of observations in regression.
@schwarz	Schwarz information criterion.
@sddep	standard deviation of the dependent variable.
@se	standard error of the regression.
@ssr	sum of squared residuals.
@stderrs(i)	standard error for coefficient i.
@totalobs	 total number of observations in the pool. For a balanced sample this is “@regobs*@ncrossest”.
@tstats(i)	t-statistic value for coefficient i.
c(i)	i-th element of default coefficient vector for the pool.
Vectors and Matrices
@coefcov	covariance matrix for coefficients of equation.
@coefs	coefficient vector.
@effects	vector of estimated fixed or random effects (only for fixed or random effects estimation).
@residcov	(sym) covariance matrix of the residuals.
@stderrs	vector of standard errors for coefficients.
@tstats	vector of t-statistic values for coefficients.
Pool Examples
To read data using the pool object:
mypool1.read(b2) data.xls x? y? z?
To delete and store pool series you may enter:
mypool1.delete x? y?
mypool1.store z?
Descriptive statistics may be computed using the command:
mypool1.describe(m) z?
To estimate a pool equation using least squares and to access the t-statistics, enter:
mypool1.ls y? c z? @ w?
vector tstat1 = mypool1.@tstats
