forcavg |
wgt=”key” | Set the type of averaging to use. key can be “mean” (default), “trmean” (trimmed-mean), “med” (median), “ols” (least squares weights), “mse” (mean square error weights), “ranks”, (MSE ranks), “aic” (Smoothed AIC weights), or “sic” (BMA weights). “aic” and “sic” are only available if a list of equations is provided as the forecast_data. |
trim=num | Set the level of trimming for the Trimmed mean method. Num should be a number between 1 and 100. Only applicable if the “trmean” option is used. |
msepwr=int | Set the power to which the MSE values are raised in the MSE ranks method. Only applicable if the “mseranks” option is used. |
s | Use a static (rather than dynamic) forecast when computing the forecasts over the training sample. Only applicable if forecast_data is a list of equation objects. |
forcsmpl=arg | Forecast sample (optional). If forecast sample is not provided, the workfile sample will be employed. |
trainsmpl=arg | Specify the sample used for calculating the averaging weights. Only applicable if the “ols”, “mse”, “mseranks”, “aic” or “sic” options are used. |
name=arg | Set the name of the final averaged series. |
wgtname=arg | Save the weights into a vector in the workfile with the name wgtname. |
