Object Reference : Object View and Procedure Reference : Series : setfillcolor : Custom Base Color
setfillcolor
Set the fill (background) color used in the series spreadsheet using values in the spreadsheet or in a different series.
series_name.setfillcolor(t=type) fill_color_args
where:
type = arg
Type of fill coloring for spreadsheet cells: “single” (single color), “posneg” (positive-negative single threshold), “range” (single range coloring), “hilo” (high-low-median), “custom” (custom coloring).
General Arguments
To specify the series or expression whose values will determine the background color:
• mapser(spec)
where spec is a series name or expression.
To specify the minimum and maximum values where the coloring begins and ends:
• min(color_arg)
• max(color_arg)
To set the missing value (NA) background color:
• naclr(color_arg)
where color_arg is described below in “Color definitions”. If omitted, the color defaults to “white”.
Type-specific Arguments
There are optional type-specific arguments that correspond to each of the type choices:
Single color
To set the single background color:
clr(color_arg)
Positive-negative single threshold
You may set the color for both the non-negative (posclr) and the negative (negclr) values
posclr(color_arg)
negclr(color_arg)
where color_arg is described below in “Color definitions”. If omitted, the non-negative color defaults to “white” and the negative color defaults to light-red.
Single range
To specify the range, you must specify the range endpoints:
range(lower_val, upper_val[, range_def)
where range_def specifies the range endpoints:
cright
closed on the right only
cboth
closed on both sides
cleft
closed on the left only
oboth
open on both sides
By default, the range will be open on the lower and closed on the upper threshold limits.
You should provide a color specification for the inside range color (inclr) and outside range color (outclr):
inclr(color_arg)
outclr(color_arg)
where color_arg is described below in “Color definitions”. If omitted, the interior color defaults to light-red, and the exterior defaults to white.
High-Low-Median
When “type=hilo” you may specify the high, low, and median coloring values:
highclr(color_arg)
lowclr(color_arg)
medianclr(color_arg)
where color_arg is described below in “Color definitions”. If omitted, the colors default to light-red.
Custom
When “type=custom” you may specify custom coloring options.
You may optionally set a base background color, and then add one or more custom threshold or range color specifications. Multiple threshold and range specifications will layer, with the first applied first, followed by the second, and so on.
Custom Base Color
To set the base color (optional):
clr(color_arg)
as described below in “Color definitions”. If omitted, the color defaults to “white”.
Custom Threshold
To add a threshold specification:
thresh(limit(threshold_value, threshold_spec), lowclr(below_arg), highclr(above_arg), threshold_name])
where threshold_spec is one of
cright
closed on the right
cleft
closed on the left
and the below_arg and above_arg are one of
color_arg
solid color specification
@grad(color_arg)
gradient using color specification
@trans
transparent
and color_arg are as described below in “Color definitions”. If omitted, the color defaults to “white”.
The optional threshold_name argument may be used to attach a name to the corresponding definition.
Custom Range
To add a range specification:
range(limit(low_value, high_value, range_spec), inclr(inside_arg), outclr(outside_arg)[, range_name])
where range_spec is one of
cright
cboth
cleft
oboth
open on both sides
inside_arg is one of
color_arg
@grad(color_arg1, color_arg2)
gradient using color specification, where color_arg1 and color_arg2 are the low and high colors, respectively.
@trans
transparent
outside_arg is one of
color_arg
@grad(color_arg)
@trans
transparent
color_arg1 and color_arg2 are as described below in “Color definitions”.
The optional range_name argument may be used to attach a name to the corresponding definition.
Color definitions
color_arg specifies the color to be employed in the arguments above. The color may be specified using predefined color names, by specifying the individual red-green-blue (RGB) components using the special “@RGB” function, or by specifying the individual red-green-blue (RGB) components in hexadecimal using the special “@HEX” function.
The predefined colors are given by the keywords (with their RGB and HEX equivalents):
blue
@rgb(0, 0, 255)
@hex(0000ff)
red
@rgb(255, 0, 0)
@hex(ff0000)
green
@rgb(0, 128, 0)
@hex(ffa8a8)
black
@rgb(0, 0, 0)
@hex(008000)
white
@rgb(255, 255, 255)
@hex(000000)
purple
@rgb(128, 0, 128)
@hex(ffffff)
orange
@rgb(255, 128, 0)
@hex(800080)
yellow
@rgb(255, 255, 0)
@hex(ff8000)
gray
@rgb(128, 128, 128)
@hex(ffff00)
ltgray
@rgb(192, 192, 192)
@hex(808080)
To set a gray background color for all cells in the spreadsheet, you may use:
myser.setfillcolor(type=single) clr(gray)
To set a background color for negative values, you may use
myser.setfillcolor(type=posneg) mapser(ser1)
which sets the background sheet fill color to white for non-negative values and light red for negative values of SER1.
Similarly,
myser.setfillcolor(type=posneg) mapser(ser1) posclr(@rgb(10, 20, 30)) negclr(purple)
sets the background sheet fill color to @rgb(10, 20, 30) for non-negative values and purple for negative values of SER1.
Range coloring may be specified using the “type=range” option. The command
myser.setfillcolor(type=range) mapser(ser1) clr(ltgray) range(10, 20, cleft) inclr(@rgb(128, 0, 128)) outclr(ltred) naclr(green)
sets the background fill to @rgb(128, 0, 128) for values between 10 and 20, light-red to values outside of the range 10 to 20, and green, for missing values.
Custom coloring allows you to construct more complex background filling:
myser.setfillcolor(type=custom) mapser(ser1) clr(@rgb(10, 0, 0)) range(limit(-10, 10, oboth), inclr(green), outclr(white))) thresh(limit(-1, oleft), highclr(grey), lowclr(@trans))
See “Value-Based Text and Fill Coloring”.
See also Series::settextcolor.
