switchvar  |
msm  | Switching mean specification (default is switching intercept).  |
exognv  | Exogenous variables are non-regime specific (default is for exogenous variables to vary).  |
endogvary  | Lagged endogenous variables are regime specific (default is for the endogenous variables to be non-varying).  |
noconst  | Do not include a constant in exogenous regressors list.  |
fprobmat=arg   | Name of fixed transition probability matrix allows for fixing specific elements of the time-invariant transition matrix. Leave NAs in elements of the matrix to estimate. The    element of the matrix corresponds to  . |
initprob=arg (default=“ergodic”)  | Method for determining initial Markov regime probabilities: ergodic solution (“ergodic”), estimated parameter (“est”), equal probabilities (“uniform”), user-specified probabilities (“user”). If “initprob=user” is specified, you will need to specify the “userinit=” option.  |
userinit=arg  | Name of vector containing user-specified initial Markov probabilities. The vector should have rows equal to the number of states; we expand this to the size of the initial lag state vector where necessary for AR specifications. For use in specifications containing both the “type=markov” and “initprob=user” options.  |
startnum=arg (default=0 or 25)  | Number of random starting values tried. The default is 0 for user-supplied coefficients (option “s”) and 25 in all other cases.  |
startiter=arg (default=10)  | Number of iterations taken after each random start before comparing objective to determine final starting value.  |
searchnum=arg (default=0)  | Number of post-estimation perturbed starting values tried.  |
searchsds=arg (default=1)  | Number of standard deviations to use in perturbed starts (if “searchnum=”) is specified.  |
seed=positive_integer from 0 to 2,147,483,647  | Seed the random number generator. If not specified, EViews will seed random number generator with a single integer draw from the default global random number generator.  |
Type of random number generator: improved Knuth generator (“kn”), improved Mersenne Twister (“mt”), Knuth’s (1997) lagged Fibonacci generator used in EViews 4 (“kn4”) L’Ecuyer’s (1999) combined multiple recursive generator (“le”), Matsumoto and Nishimura’s (1998) Mersenne Twister used in EViews 4 (“mt4”).  |
optmethod = arg  | Optimization method: “bfgs” (BFGS); “newton” (Newton-Raphson), “opg” or “bhhh” (OPG or BHHH), “legacy” (EViews legacy). BFGS is the default method.  |
optstep = arg  | Step method: “marquardt” (Marquardt); “dogleg” (Dogleg); “linesearch” (Line search). Marquardt is the default method.  |
m=integer  | Set maximum number of iterations.   |
c=scalar  | Set convergence criterion. The criterion is based upon the maximum of the percentage changes in the scaled coefficients. The criterion will be set to the nearest value between 1e-24 and 0.2.   |
cov=arg  | Covariance method: “ordinary” (default method based on inverse of the estimated information matrix), “huber” or “white” (Huber-White sandwich method).  |
covinfo = arg  | Information matrix method: “opg” (OPG); “hessian” (observed Hessian). (Applicable when non-legacy “optmethod=”.)   |
nodf  | Do not degree-of-freedom correct the coefficient covariance estimate.  |
coef=arg  | Specify the name of the coefficient vector (if specified by list); the default behavior is to use the “C” coefficient vector.  |
s  | Use the current coefficient values in “C” as starting values (see also
    param).  |
s=number  | Specify a number between zero and one to determine starting values as a fraction of EViews default values (out of range values are set to “s=1”).  |
showopts / ‑showopts  | [Do / do not] display the starting coefficient values and estimation options in the estimation output.  |
prompt  | Force the dialog to appear from within a program.  |
p  | Print results.  |
