Function Reference: G
    @gamma	(Complete) gamma function.
    @gammader	First derivative of the gamma function.
    @gammalog	Natural logarithm of the gamma function.
    @getnextname	String containing next available name in the workfile.
    @grid	Vector containing equally spaced grid of values.
Syntax:		@gamma(x)
	x:	number
Return:		number
for
Related, stable calculations for the logarithm of @gamma may be obtained using
@gammalog.
= @gamma(5)
returns 24 (equivalent to
= @gamma(0.5)
returns 1.77245... (equivalent to
Derivative (first) of the gamma function.
Syntax:		@gammader(x)
	x:	number
Return:		number
for
Note: Euler’s constant,  , may be evaluated as
, may be evaluated as  .
. Examples
= @gammader(1)
returns -0.57721....
See also
@gamma and
@digamma.
Incomplete gamma function.
Syntax:		@gammainc(x, a[, u])
	x:	number
	a:	number
	u:	(optional) number
Return:		number
for  and
 and  .
. If the optional argument u is non-zero, return the upper-tail value:
|  | (18.7) |
= @gammainc(1,1)
returns 0.63212... (equivalent to
Derivative of the incomplete gamma integral.
Syntax:		@gammaincder(x, a, c)
	x:	number
	a:	number
	c	integer
Return:		number
Given the incomplete gamma integral for elements of x and a:
for
 and
, compute the derivative given by
c where
c is an integer from 1 to 5 indicating the desired derivative,
If
c is not an integer, the integer floor
 will be used.
= @gammaincder(1,3,1)
returns 0.18393....
Inverse of the incomplete gamma function.
Syntax:		@gammainciv(p, a)
	x:	number
	p:	number
	a:	number
Return:		number
Find the value of
 satisfying:
for  and
 and  .
. Examples
= @gammaincinv(0,2)
returns 0.
Syntax:		@gammalog(x)
	x:	number
Return:		number
for
= @gammalog(3)
returns 0.69314....
Extract main diagonal from matrix.
Syntax:		@getmaindiagonal(m)
	m:	matrix, vector, sym
Return:		vector
Returns a vector created from the main diagonal of the matrix or sym object. The main diagonal is defined as the elements {(1, 1), (2, 2), ..., (k, k)} of the matrix, where k is the smaller of the number of rows and columns.
If M1 is an
 identity matrix, then
= @getmaindiagonal(m1)
returns an n-vector of ones.
Syntax:		@getnextname(str)
	str:	string,
Return:		string
Returns a string containing the next available variable name in the workfile, starting with str (i.e. entering “result” will return “RESULT01” unless there is already a RESULT01, in which case it will return “RESULT02”).
%objname = @getnextname("eqtest")
equation {%objname}.ls y c x1 x2 x3
assigns the next available name to the string variable %OBJNAME, and then uses the name to estimate an equation in the workfile.
Object type of active object (_this)
Syntax:		@getthistype
Return:		string
If no workfile is open, or if no object has yet been opened in a workfile, the function will return the string "NONE".
This latter behavior is in contrast to using the data member syntax “_this.@type”, which will generate an error in cases like this where the active object is undefined.
See also the
@type data member of each object in
“Object View and Procedure Reference”.
See
“The Active Object Keyword” for a discussion of the _THIS active object.
Geometric mean.
Computes the geometric mean of the elements of
x for
Syntax:		@gmean(x[, s])
	x:	 series, vector, matrix
	s:	(optional) sample string or object when x is a series and assigning to a series
Return:		number
The geometric mean is calculated as
If x is a series of length 3 with elements 1, 2, and 4, then
= @gmean(x)
returns 2 (= the cube root of 8).
See also
@mean,
@hmean, and
@trmean.
Syntax:		@grid(d1, d2, n)
	d1:	number
	d2:	number
	n:	integer
Return:		vector
Returns a vector holding an arithmetic sequence of n elements. The initial element has value d1, the last element is d2, and there are equal increments between rows of the vector.
vector v1 = @grid(0, 3, 10)
creates V1, a 10-element vector with first element 0, last element 3, and equal increments between successive rows of the vector.
vector cdf1 = @cnorm(@grid(-2.0, 2.0, 401))
creates a 401-element vector of normal CDF ordinates evaluated at points from -2.0 to 2.0.
