Function Reference: M
@mae Mean of absolute error (difference) between series.
@makedate Convert numeric representation of a date to date number.
@mape Mean absolute percentage error (difference) between series.
@mav Trailing moving averages (ignore NAs).
@mavc Centered moving averages (ignore NAs).
@maxerrcount Maximum number of errors in a program before halting execution.
@maxes Maximum values (multiple).
@maxsby Maximum values in a series for each specified group.
@mcor Trailing moving correlations (ignore NAs).
@mcov Trailing moving population covariance (no d.f. adjustment; ignore NAs).
@mcovp Trailing moving population covariance (no d.f. adjustment; ignore NAs).
@mcovs Trailing moving sample covariance (d.f. adjusted; ignore NAs).
@meansby Mean of observations in a series for each specified group.
@mediansby Medians for a series for each specified group.
@mid Substring in middle or from middle to end of string.
@minner Trailing moving inner product of two series (ignore NAs).
@mins Minimum values (multiple).
@minsby Minimum values in a series for each specified group.
@minute Minute of the hour of the observation.
@mkurt Trailing moving kurtosis (ignore NAs).
@mmax Trailing moving maximums (ignore NAs).
@mmedian Trailing moving median (ignore NAs).
@mmin Trailing moving minimums (ignore NAs).
@mnas Trailing moving missing observations.
@mnrnd Matrix of normal random numbers.
@mobs Trailing moving non-missing observations.
@mod Floating point remainder.
@month Month of the year of the observation.
@movav Trailing moving averages (propagate NAs).
@movavc Centered moving averages (propagate NAs).
@movcor Trailing moving population correlations (propagate NAs).
@movcov Trailing moving population covariance (no d.f. adjustment; propagate NAs).
@movcovp Trailing moving population covariance (no d.f. adjustment; propagate NAs).
@movcovs Trailing moving sample covariance (d.f. adjusted; propagate NAs).
@movinner Trailing moving inner product of two series (propagate NAs).
@movkurt Trailing moving kurtosis (propagate NAs).
@movmax Trailing moving maximums (propagate NAs).
@movmedian Trailing moving median (propagate NAs).
@movmin Trailing moving minimums (propagate NAs).
@movskew Trailing moving skewness (propagate NAs).
@movstdev Trailing moving sample standard deviations (d.f. adjusted; propagate NAs).
@movstdevp Trailing moving population standard deviations (non-d.f. adjusted; propagate NAs).
@movstdevs Trailing moving sample standard deviations (d.f. adjusted; propagate NAs).
@movsum Trailing moving sums (propagate NAs).
@movsumsq Trailing moving sums of squares (propagate NAs).
@movvar Trailing moving population variances (non d.f. adjusted; propagate NAs).
@movvarp Trailing moving population variances (non-d.f. adjusted; propagate NAs).
@movvars Trailing moving sample variances (d.f. adjusted; propagate NAs).
@mrnd Matrix of uniform random numbers.
@mse Mean of square error (difference) between series.
@mskew Trailing moving skewness (ignore NAs).
@mstdev Trailing moving sample standard deviation (d.f. adjusted; ignore NAs).
@mstdevp Trailing moving population standard deviations (non-d.f. adjusted; ignore NAs).
@mstdevs Trailing moving sample standard deviations (d.f. adjusted; ignore NAs).
@msum Trailing moving sums (ignore NAs).
@msumsq Trailing moving sums of squares (ignore NAs).
@mvar Trailing moving population variances (non-d.f. adjusted; ignore NAs).
@mvarp Trailing moving population variances (non-d.f. adjusted; ignore NAs).
@mvars Trailing moving population variances (d.f. adjusted; ignore NAs).
Computes the mean of the absolute difference between x and y.
Syntax: @mae(x, y, [s])
x: series
y: series
s: (optional) sample string or object
Return: series
EViews will use the current or specified workfile sample.
Let yf denote in-sample forecasts for the series y. Then
= @mae(yf, y)
returns the MAE between the series y and its forecast.
Syntax: @makedate(arg1[, arg2[,arg3]], fmt)
arg1: number
args: (optional) number(s) arg2, arg3, ...
fmt: date format
Return: date number
Takes the numeric values given by the arguments arg1, and optionally, arg2, etc. and returns a date number using the required format string, fmt.
If more than one argument is provided, the arguments must be listed from the lowest frequency to the highest, with the first field representing either the year or the hour.
The expressions,
@makedate(1999, "yyyy")
@makedate(99, "yy")
both return the date number 729754.0 corresponding to 12 midnight on January 1, 1999.
@makedate(199003, "yyyymm")
@makedate(1990.3, "yyyy.mm")
@makedate(1031990, "ddmmyyyy")
@makedate(30190, "mmddyy")
all return the value 726526.0, representing March 1, 1990.
Dates may be created using multiple arguments. The expressions,
@makedate(97, 12, 3, "yy mm dd")
@makedate(1997, 12, 3, "yyyymmdd")
will return the value 729360.0 corresponding to midnight on December 3, 1997. You may provide a subset of this information so that
@makedate(97, 12, "yymm")
returns the value 729358.0 representing the earliest date and time in December of 1997 (12 midnight, December 1, 1997). Likewise,
@makedate(1997, 37, "yyyy ddd")
yields the value 729060.0 (February 6, 1997, the 37th day of the year) and
@makedate(14, 25, 10, "hh mi ss")
fills the series YM with date numbers for observations in the workfile sample.
If Y is a series containing year data, M is a series containing month data, and DT is a series containing day data,
series ymd = @makedate(y, m, dt, "yyyymmdd")
fills the series YMDSTR with date numbers formed using those series, for observations in the workfile sample.
Let MYDATE is a series that contains values with the year and month combined in a single number (e.g., “201011”, “200505”),
mydate = y * 100 + m
series ym = @makedate(mydate, "yyyymm")
Then YM contains the date number associated with MYDATE.
If YVEC is a vector with (hour*10000 + minute*100 + seconds) values,
vector yearvec = @makedate(yvec, "hhmiss")
fills YEARVEC with the date numbers associated with each element of YVEC.
See
@datestr for string representations of date numbers.
Create a matrix with vector placed on a diagonal.
Syntax: @makediagonal(v[, k])
v: vector, rowvector
k: (optional) integer
Return: sym or matrix
Create a square matrix with v placed in the k-th diagonal relative to the main diagonal, and zeros off the diagonal.
• If no k value is provided or if k is set to 0, the resulting sym matrix will have the same number of rows and columns as the length of v, and will have v in the main diagonal.
• If a value for k is provided, the matrix has the same number of rows and columns as the number of elements in the vector plus k, and will place v in the diagonal offset from the main by k.
sym s1 = @makediagonal(v1)
matrix m2 = @makediagonal(v1,1)
matrix m4 = @makediagonal(r1,-3)
S1 will contain V1 in the main diagonal; M2 will contain V1 in the diagonal immediately above the main diagonal; M4 will contain R1 in the diagonal 3 positions below the main diagonal. Using the optional k parameter may be useful in creating covariance matrices for AR models. For example, you can create an AR(1) correlation matrix by issuing the commands:
matrix(10,10) m1
vector(9) rho = .3
m1 = @makediagonal(rho,-1) + @makediagonal(rho,+1)
m1 = m1 + @identity(10)
Note that to make a diagonal matrix with the same elements on the diagonal, you may use @identity, multiplied by the scalar value.
Make string into a valid EViews name.
Syntax: @makevalidname(str)
str: string
Return: string
Returns a string containing an uppercased valid EViews name based on str.
• If str is a valid name, then the original string str is returned.
• If str exceeds the maximum length, the resulting string will be truncated.
• If str is not a valid name, invalid characters will be replaced in the new string with “_” prior to the return.
@makevalidname("re!sult%")
returns the string “RE_SULT_”.
@makevalidname("evname01")
returns the string “EVNAME01”.
If ALPHA1 is an alpha series,
alpha a1 = @makevalidname(alpha1)
returns valid EViews names based on ALPHA1 for each observation in the workfile sample.
If SVEC1 is an string vector,
svector sv1 = @makevalidname(svec1)
returns a string vector containing valid names corresponding to elements of SVEC1.
Computes the mean of the absolute percentage difference between x and y.
Syntax: @mape(x, y, [s])
x: series
y: series
Return: number
= @mape(yf, y)
returns the MAPE between the series y and its forecast.
n-period trailing moving averages, ignoring NAs.
Syntax: @mav(x, n)
x: series
n integer, series
Return: series
For each observation
and integer
, compute the average () using the current and previous
observations of the series,
and ignoring missing values (NAs).
If
n is not an integer, the integer floor
will be used.
show @mav(x, 12)
produces a linked series of the moving average of the series x where NAs are ignored.
See also
@mavc for a centered moving average.
For the NA-propagating variant of this function, see
@movav.
n-period centered moving averages, ignoring NAs.
Syntax: @mavc(x, n)
x: series
n integer, series
Return: series
and integer
• If
is odd, compute the average of the current, and
previous and subsequent observations of a series,
where
. If missing values are encountered, the observation is discarded, and the divisor for the mean is adjusted to compensate.
• If
is even, compute the
period centered moving sum, weighting the endpoints by 1/2, then divide by
where
and
If
will be used.
show @mavc(x, 12)
produces a linked series of the centered moving average of the series x where NAs are ignored.
See also
@mav for a trailing moving average.
@movavc.
Maximum value.
Finds the maximum value of the elements of x.
Syntax: @max(x[, s])
x: series, vector, matrix
s: (optional) sample string or object when x is a series and assigning to series
Return: number
The maximum may be written as
where the order statistics
represent the data ordered from low to high.
Let x be a series of length 5 whose elements are 1, 3, 5, 4, 2. Then
= @max(x)
returns 5.
See also
@imax,
@min, and
@maxes.
Syntax: @maxerrcount
Return: integer
Returns an integer containing the current value of the maximum number of errors that a program may encounter before execution is halted.
May only be used in a program.
Vector of the n maximum values of the elements of x.
Syntax: @max(x, n[, s])
s: (optional) sample string or object when x is a series and assigning to a series
Return: vector
The maximum n values may be written as
= @maxes(x,2)
returns a vector of length 2 whose elements are 5 and 4.
See also
@imaxes,
@mins, and
@max.
Syntax: @maxsby(x, y[y1, y2, ... yn, s])
x: series
y series, alpha
Return: series
Returns the maximum value in x each group defined by distinct values of y.
show @maxsby(x, g1, g2)
produces a linked series of the by-group maximums of the series x, where members of the same group have identical values for both g1 and g2.
n-period trailing moving Pearson product moment correlations between a pair of variables, with d.f. correction, ignoring NAs.
Syntax: @mcor(x, y, n)
x: series
y: series
n integer, series
Return: series
and integer
, compute the correlations () using the current and previous
If
will be used.
show @mcor(x, y, 12)
produces a linked series of the moving population correlation of the series x and y where NAs are ignored.
See also
@mcov for NA-excluding trailing moving covariances
@movcor.
n-period trailing moving Pearson product moment population covariances between a pair of variables, with no d.f. correction, ignoring NAs.
Syntax: @mcov(x, y, n)
x: series
y: series
n integer, series
Return: series
and integer
, compute the population covariance () using the current and previous
If
will be used.
show @movcov(x, y, 12)
produces a linked series of the moving population covariance of the series x and y where NAs are ignored.
See also
@mcovp and
@mcovs for NA-excluding covariances.
@movcov.
Syntax: @mcovp(x, y, n)
x: series
y: series
n integer, series
Return: series
and integer
If
will be used.
Equivalent to @mcov.
show @mcovp(x, y, 12)
See also
@mcov and
@mcovs.
@movcovp.
n-period trailing moving Pearson product moment sample covariances between a pair of variables, with d.f. correction, ignoring NAs.
Syntax: @mcovs(x, y, n)
x: series
y: series
n integer, series
Return: series
and integer
, compute the sample covariance () using the current and previous
If
will be used.
show @mcov(x, y, 12)
produces a linked series of the moving sample covariance of the series x and y where NAs are ignored.
See also
@mcov and
@mcovp.
@movcovs.
Arithmetic mean.
Computes the arithmetic mean of the elements of x.
Syntax: @mean(x[, s])
Return: number
= @mean(x)
returns the sample mean of a series x. If x = @rnd, then @mean(x) will be near 0.5 in large samples.
Mean of observations in a series for each specified group defined by distinct values.
Syntax: @meansby(x, y[y1, y2, ... yn, s])
x: series
y1...yn series, alpha, group
Return: series
Compute the mean of observations in x for group identifiers defined by distinct values of y, using the current or specified workfile sample.
show @meansby(x, g1, g2)
produces a linked series of by-group means of the series x, where members of the same group have identical values for both g1 and g2.
Median.
Computes the median of the elements of x.
Syntax: @median(x[, s])
Return: number
When
is odd, the median is the middle ordered-observation and when
is even, the median is the average of the two middle ordered-observations. The median may be written as
Let x be a series of length 6 with observations 1, 2, 3, 4, 5, 6. Then
= @median(x)
returns 3.5.
Medians for a series for each specified group defined by distinct values.
Syntax: @medians(x, y[y1, y2, ... yn, s])
x: series
Return: series
Returns the median of x each group defined by distinct values of y, using the current or specified workfile sample.
show @mediansby(x, g1, g2)
produces a linked series of the by-group sample medians of the series x, where members of the same group have identical values for both g1 and g2.
Syntax: @mid(str, n1[, n2])
str: string, alpha, svector
n1: integer, series, vector
n2: (optional) integer, series, vector
Return: string, alpha, svector
Returns n2 characters from str, starting at location n1 and continuing for n2 characters to the right. If you omit n2, it will return all of the remaining characters in the string.
The command
string s1 = @mid("I doubt it", 5)
assigns “ubt it” to the string object S1, while
string s2 = @mid("I doubt it", 5, 2)
assigns “ub” to S2.
alpha a1 = @mid(alpha1, 7)
returns the characters beginning with the 7th from the string values of ALPHA1 for each observation in the workfile sample.
If LETTER_ID is a numeric series with integer values from 1 to 26, then
string alphabet = "abcdefghijklmnopqrstuvwxyz"
alpha letter = @mid(alphabet, letter_id, 1)
will lookup the letter associated with each value of LETTER_ID for observations in the workfile sample.
svector sv1 = @mid(svec1, 12, 5)
returns an svector beginning at the 12th for 5 characters for each element of SVEC1.
See also
@wmid,
@left and
@right.
Minimum value.
Finds the minimum value of the elements of x.
Syntax: @min(x[, s])
x: data object
s: (optional) sample string or object when x is a series or alpha and assigning to series or alpha
Return: number or string
The minimum may be written as
= @min(x)
returns 1.
See also
@imin,
@mins, and
@max.
n-period moving inner product of two variables for the current and previous
observations, ignoring NAs.
Syntax: @minner(x, y, n)
x: series
y: series
n integer, series
Return: series
and integer
, compute the inner product of the current and previous
If
will be used.
show @minner(x, y, 12)
produces a linked series of the moving inner product of the series x and y where NAs are ignored.
@movinner.
Vector or svector the n minimum values of the elements of x.
Syntax: @mins(x, n[, s])
x: data object
Return: vector or svector
The minimum n values may be written as
= @mins(x,2)
returns a vector of length 2 whose elements are 1 and 2.
See also
@imins,
@min, and
@maxes.
Syntax: @minsby(x, y[y1, y2, ... yn, s])
x: series
y series or alpha
Return: series or alpha
Returns the minimum value in x each group defined by distinct values of y.
show @minsby(x, g1, g2)
produces a linked series of the by-group minimums of the series x, where members of the same group have identical values for both g1 and g2.
Syntax: @minute
Return: series
Returns the minute of the hour (0-59) associated with each observation in the workfile.
• If the workfile is of lower than minute frequency, all observations will be set to 0.
• If the workfile is undated, observations will be set to -1.
series dt = @minute
saves the minute of the hour into the series DT.
The command
smpl if @hourf >= 50
sets the sample to only include the last 10 minutes of each hour.
n-period trailing moving kurtosis, ignoring NAs.
Syntax: @mkurt(x, n)
x: series
n integer, series
Return: series
and integer
, compute the average using the current and previous
If
will be used.
show @mkurt(x, 12)
produces a linked series of the moving kurtosis of the series x where NAs are ignored.
See also
@mskew for centered moving skewness.
@movkurt.
n-period trailing maximums, ignoring NAs.
Syntax: @mmax(x, n)
x: series
n integer, series
Return: series
and integer
, compute the maximum () using the current and previous
If
will be used.
show @mmax(x, 12)
produces a linked series of maximums based on a 12-period moving window over the series x where NAs are ignored.
See also
@mmin for moving minimums.
@movmax.
n-period trailing moving median, ignoring NAs.
Syntax: @mmedian(x, n)
x: series
n integer, series
Return: series
and integer
, compute the median using the current and previous
If
will be used.
show @mmedian(x, 12)
produces a linked series of the moving median of the series X where NAs are ignored.
@movmax.
n-period trailing minimums, ignoring NAs.
Syntax: @mmin(x, n)
x: series
n integer, series
Return: series
and integer
, compute the minimum () using the current and previous
If
will be used.
show @mmin(x, 12)
produces a linked series of minimums based on a 12-period moving window over the series x where NAs are ignored.
@movmin.
n-period trailing number of missing observations, ignoring NAs.
Syntax: @mnas(x, n)
x: series, alpha
n integer, series
Return: series
and integer
, count the number of missing (NA) observations in the current and previous
Equivalent to @movnas.
show @mnas(x, 12)
produces a linked series of NA counts based on a 12-period moving window over the series x.
Syntax: @mnrnd(n1[, n2])
n1: integer
Return: matrix
Creates a matrix filled with normal
random numbers. The size of the matrix is given by the integers
n1 (number of rows) and
n2 (number of columns).
matrix m1 = @mnrnd(3,2)
creates a
matrix filled with standard normal random numbers.
If n2 is omitted or set to 1, the function returns a vector as in
vector v1 = @mnrnd(18)
You may obtain a random sym of normal numbers by creating a square source matrix of random normals and assigning it to a sym matrix,
sym s1 = @mnrnd(5, 5)
which creates the sym S1 based on the lower triangle of the source matrix.
See also
@mrnd,
nrnd, and
rnd.
n-period trailing number of non-missing observations, ignoring NAs.
Syntax: @mobs(x, n)
x: series, alpha
n integer, series
Return: series
and integer
, count the number of non-missing (non-NA) observations in the current and previous
Equivalent to @movobs.
show @mobs(x, 12)
produces a linked series of non-NA counts based on a 12-period moving window over the series x.
Syntax: @mod(x, y)
x: number
y: number
Return: number
For non-zero
, returns the decimal remainder of
with the same sign as
where
is the integer floor function.
If
returns 0.
= @mod(4,3)
returns 1.
Syntax: @month
Return: series
Returns the month of the year (1–12) associated with each observation in the workfile.
• If the workfile is of lower than monthly frequency, all observations will be set to 1.
series dt = @month
saves the month into the series DT.
The command
smpl if @month=12 or @month=1
sets the sample to only include observations in December and January.
n-period trailing moving averages, propagating NAs.
Syntax: @movav(x, n)
x: series
n integer, series
Return: series
and integer
and propagating missing values (NAs).
If
will be used.
show @movav(x, 12)
produces a linked series of the moving average of the series x where NAs are propagated.
See also
@movavc for trailing moving averages.
For the NA-ignoring variant of this function, see
@mav.
n-period centered moving averages, propagating NAs.
Syntax: @movavc(x, n)
x: series
n integer, series
Return: series
and integer
• If
previous and subsequent observations of a series, propagating missing values (NAs)
where
• If
period centered moving sum, weighting the endpoints by 1/2 and propagating missing values (NAs), then divide by
where
and
If
will be used.
show @movavc(x, 12)
produces a linked series of the centered moving average of the series x where NAs are propagated.
See also
@movav for trailing moving averages.
For the NA-excluding variant of this function, see
@mavc.
n-period trailing moving Pearson product moment population correlations between a pair of variables, with d.f. correction, propagating NAs.
Syntax: @movcor(x, y, n)
x: series
y: series
n integer, series
Return: series
and integer
If
will be used.
show @movcor(x, y, 12)
produces a linked series of the moving population correlation of the series x and y where NAs are propagated.
See also
@movcor for moving correlation, and
@movcov and
@movcovs for trailing moving covariances.
See
@mcor for an NA-excluding version of this function.
n-period trailing moving Pearson product moment population covariances between a pair of variables, with no d.f. correction, propagating NAs.
Syntax: @movcov(x, y, n)
x: series
y: series
n integer, series
Return: series
and integer
If
will be used.
produces a linked series of the moving population covariance of the series x and y where NAs are propagated.
See also
@movcovp and
See
@mcov for NA-excluding version of this function.
n-period trailing moving Pearson moment population covariances between a pair of variables, with no d.f. correction, propagating NAs.
Syntax: @movcovp(x, y, n)
x: series
y: series
n integer, series
Return: series
and integer
If
will be used.
Equivalent to @movcov.
show @movcovp(x, y, 12)
See
@mcovp for NA-excluding version of this function.
n-period trailing moving Pearson product moment sample covariances between a pair of variables, with d.f. correction, propagating NAs.
Syntax: @movcovs(x, y, n)
x: series
y: series
n integer, series
Return: series
and integer
If
will be used.
produces a linked series of the moving sample covariance of the series x and y where NAs are propagated.
See also
@movcov and
@movcovp.
See
observations, propagating NAs.
Syntax: @movinner(x, y, n)
x: series
y: series
n integer, series
Return: series
and integer
If
will be used.
show @movinner(x, y, 12)
produces a linked series of the moving inner product of the series x and y where NAs are propagated.
See also
@movsumsq for the trailing moving sums-of-squares.
See
@minner for an NA-excluding version of this function.
n-period trailing moving kurtosis, propagating NAs.
Syntax: @movkurt(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
show @movkurt(x, 12)
produces a linked series of the moving kurtosis of the series x where NAs are propagated.
See also
@movskew for the trailing moving skewness.
See
@mkurt for an NA-excluding version of this function.
n-period trailing maximums, propagating NAs.
Syntax: @movmax(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
show @movmax(x, 12)
produces a linked series of maximums based on a 12-period moving window over the series x where NAs propagate.
@mmax.
Syntax: @movmedian(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
show @movmedian(x, 12)
produces a linked series of the moving median of the series X where NAs are propagated.
@mmedian.
n-period trailing minimums, propagating NAs.
Syntax: @movmin(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
show @movmin(x, 12)
produces a linked series of minimums based on a 12-period moving window over the series x where NAs propagate.
n-period trailing moving skewness, propagating NAs.
Syntax: @movskew(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
show @movskew(x, 12)
produces a linked series of the moving skew of the series x where NAs are propagated.
@mskew.
n-period trailing moving square roots of Pearson product moment sample variances, with d.f. correction, propagating NAs.
Syntax: @movstdev(x, n)
x: series
n integer, series
Return: series
and integer
, compute the sample standard deviation () using the current and previous
If
will be used.
show @movstdev(x, 12)
produces a linked series of the moving sample standard deviation of the series x where NAs are propagated.
@mstdev.
n-period trailing moving square roots of (population) Pearson product moment population variances, with no d.f. correction, propagating NAs.
Syntax: @movstdevp(x, n)
x: series
n integer, series
Return: series
and integer
, compute the population standard deviation () using the current and previous
If
will be used.
show @movstdevp(x, 12)
produces a linked series of the moving population standard deviation of the series x where NAs are propagated.
@mstdevp.
Syntax: @movstdevs(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
Equivalent to @movstdev.
show @movstdevs(x, 12)
@mstdevs.
n-period trailing moving sums, propagating NAs.
Syntax: @movsum(x, n)
x: series
n integer, series
Return: series
and integer
, compute the sum () using the current and previous
If
will be used.
show @movsum(x, 12)
produces a linked series of the moving sum of the series x where NAs are propagated.
@msum.
n-period trailing moving sums of squares, propagating NAs.
Syntax: @movsumsq(x, n)
x: series
n integer, series
Return: series
and integer
, compute the sums of squares () using the current and previous
If
will be used.
show @movsumsq(x, 12)
produces a linked series of the moving sum of squares of the series x where NAs are propagated.
@msumsq.
n-period trailing moving Pearson product moment population variances, with no d.f. correction, propagating NAs.
Syntax: @movvar(x, n)
x: series
n integer, series
Return: series
and integer
, compute the sample variance () using the current and previous
observations of the series,propagating missing values (NAs).
If
will be used.
show @movvar(x, 12)
produces a linked series of the moving population variance of the series x where NAs are propagated.
@mvar.
Syntax: @movvarp(x, n)
x: series
n integer, series
Return: number
and integer
, compute the population variance () using the current and previous
If
will be used.
Equivalent to @movvar.
show @movvarp(x, 12)
@mvarp.
n-period trailing moving Pearson product moment sample variances, with d.f. correction, propagating NAs.
Syntax: @movvars(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
show @movvars(x, 12)
produces a linked series of the moving sample variance of the series x where NAs are propagated.
@mvars.
Syntax: @mrnd(n1[, n2])
n1: integer
Return: matrix
Creates a matrix filled with uniform (0, 1) random numbers. The size of the matrix is given by the integers n1 (number of rows) and n2 (number of columns).
matrix m1 = @mrnd(3,2)
creates a
matrix filled with uniform random numbers.
vector v1 = @mrnd(18)
You may obtain a random sym of uniform numbers by creating a square source matrix of uniform numbers and assigning it to a sym matrix,
sym s1 = @mrnd(5, 5)
See also
@mnrnd,
nrnd, and
rnd.
Mean of square error (difference) of two series.
Computes the mean of the squared difference between x and y.
Syntax: @mse(x, y, [s])
x: series
y: series
Return: number
= @mse(yf, y)
returns the MSE between the series y and its forecast.
n-period trailing moving skewness, ignoring NAs.
Syntax: @mskew(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
show @mskew(x, 12)
produces a linked series of the moving skew of the series x where NAs are ignored.
See also
@mkurt for moving kurtosis.
@movskew.
n-period trailing moving square roots of Pearson product moment sample variances, with d.f. correction, ignoring NAs.
Syntax: @mstdev(x, n)
x: series
n integer, series
Return: series
and integer
, compute the sample standard deviation (division by
If
will be used.
show @mstdev(x, 12)
produces a linked series of the moving sample standard deviation of the series x where NAs are ignored.
@movstdev.
n-period trailing moving square roots of Pearson product moment population variances, with no d.f. correction, ignoring NAs.
Syntax: @mstdevp(x, n)
x: series
n integer, series
Return: series
and integer
, compute the population standard deviation using the current and previous
If
will be used.
show @mstdevp(x, 12)
produces a linked series of the moving population standard deviation of the series x where NAs are ignored.
@movstdevp.
Syntax: @mstdevs(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
Equivalent to @mstdev.
show @mstdevs(x, 12)
@movstdevs.
n-period trailing moving sums, ignoring NAs.
Syntax: @msum(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
show @msum(x, 12)
produces a linked series of the moving sum of the series x where NAs are ignored.
@movsum.
n-period trailing moving sums of squares, ignoring NAs.
Syntax: @msumsq(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
show @msumsq(x, 12)
produces a linked series of the moving sum of squares of the series x where NAs are ignored.
@movsumsq.
Syntax: @mvar(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
show @mvar(x, 12)
produces a linked series of the moving population variance of the series x where NAs are ignored.
@movvar.
n-period trailing moving square roots of population Pearson product moment variance, with no d.f. correction, ignoring NAs.
Syntax: @mvarp(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
Equivalent to @mvar.
show @mvarp(x, 12)
@movvarp.
Syntax: @mvars(x, n)
x: series
n integer, series
Return: series
and integer
If
will be used.
show @mvars(x, 12)
produces a linked series of the moving sample variance of the series x where NAs are ignored.
@movvars.
