Object Reference : Object Command Summary : W
W
wald O:193, O:432, O:552, O:756, O:841
Wald test UII:1076, O:193, O:432, O:552, O:756, O:841
coefficient restriction UII:1076
demonstration UI:18
formula UII:1081
F-statistic UII:1082
joint restriction UII:1078
nonlinear restriction UII:1081
structural change with unequal variance UII:1128
Warning on close option UI:2091
Watson test UI:441, O:612
@wcount C:82, C:673
@wcross C:88, C:674
@wdelim C:88, C:674
@wdir C:91, C:792
@wdrop C:86, C:675
Weak instruments UII:972, UII:988, O:194
weakinst O:194
@weekday C:113, C:493, C:623
Weibull distribution C:595
Weibull function
CDF C:607
density C:609
inverse CDF C:616
random number generator C:618
Weight functions
M-estimation 1:1318, O:170
S-estimation 1:1322
Weighted least squares UII:941, O:842
cross-equation weighting UII:1590
nonlinear UII:952
nonlinear two stage UII:971, UII:982
pool UII:1865
system estimation UII:1619
two stage in systems UII:1591, UII:1621
weight scaling UII:943
weight type UII:943
Weighted two-stage least squares O:843
Weighting matrix
GMM UII:977, UII:984
heteroskedasticity and autocorrelation consistent (HAC) in system GMM UII:1625
heteroskedasticity and autocorrelation consistent (HAC) robust standard errors UII:939
kernel options (system) UII:1625
system GMM UII:1624
White (cointegrating regression) UII:1173
White (GMM) UII:984
White (panel cointegrating regression) 1:1977
White (robust standard errors) UII:927
White (system GMM) UII:1624
Welsch function 1:1319
wend C:792
@wexpand C:639
wfclose C:522
wfcompare C:523
wfcreate C:525
wfdetails C:529
wfdir C:530
@wfind C:83, C:675
@wfindnc C:676
@wfname C:622
wfopen C:530
wforder C:545
@wfpath C:622
wfsave C:546
wfselect C:551
wfsnapshot C:551
wfstats C:552
wfunlink C:552
wfuse C:553
while C:793
While loop C:150
abort C:151
end of C:792
exit loop C:153
start of C:793
white O:194, O:964
White heteroskedasticity consistent covariance matrix
cointegrating regression UII:1173
GMM UII:984
panel cointegrating regression 1:1977
robust standard errors UII:927
system GMM UII:1624
White heteroskedasticity test UII:1093, O:119
VAR UII:1650
Whitening UI:634, UI:641, O:376, O:632
width O:727
Width of table column UI:832
Wilcoxon test O:671
rank sum UI:438, O:670
signed ranks UI:434, O:671
Wildcard characters UI:61, C:29, C:797
in easy query UI:342
Windmeijer standard errors UII:981, C:381, O:113
Window
active UI:113
database UI:327
docking and moving C:10
EViews main UI:89
object UI:115
Windows
command shell C:496
environment variables C:764
Windows shell C:489
@winterleave C:88, C:676
@wintersect C:87, C:677
Wishart density C:609
Wishart density (Cholesky covariance) C:609
Wishart density (Cholesky inverse covariance) C:609
Wishart density (inverse covariance) C:609
Wishart distribution C:597
Wishart random number generator C:618
Wishart random number generator (Cholesky covariance) C:618
Wishart random number generator (Cholesky inverse covariance) C:618
Wishart random number generator (inverse covariance) C:618
Within deviations UII:1904, UII:1912
Within factors UI:775
identification UI:779
@wjoin C:90, C:677
@wkeep C:85, C:678
@wleft C:84, C:678
@wlookup C:91, C:793
wls O:842
@wmid C:85, C:679
@wnotin C:87, C:679
Word
pasting graphs and data into 1:865
@word C:85, C:680
@wordq C:85, C:680
Work area UI:93
Workfile C:26, C:463
activate C:553
append to UI:299, C:442
applying structure to UI:281
attributes UI:50, C:398, C:529
automatic backup UI:66, UI:2100
close C:27, C:522
common structure errors UI:294
comparing UI:80, C:523
contract UI:302, C:443
convert repeated obs to repeated series C:466
convert repeated series to repeated obs C:460
copy from UI:302, C:444
create UI:30, C:342, C:525
create page in C:446
date strings C:90, C:113, C:624
define structured page C:463
delete page C:452, C:453, C:545
description of UI:29
details C:529
details display UI:50
directory UI:49, C:530
display statistics view C:552
end date of observation interval C:622
export UI:323, C:546
filtering objects UI:61
find objects C:91, C:793
frequency C:26
@-functions C:599
functions C:621
import C:390
import foreign source into C:390
information C:621
load existing from disk UI:69
load workfile pages into C:452
multi-page UI:70
number of observations in C:621
observation date functions C:113, C:623
observation numbers UI:128, C:621
open existing C:27, C:530
open foreign source into C:530
order C:545
panel UII:1891
panel structured C:621
panel to pool C:466
period indicators C:624
pool UII:1841, UII:1850
pool to panel C:460
remove structure UI:296
rename page C:454
reshape UI:306
resize UI:283, UI:296
retrieve name of C:622
retrieve path of C:622
sample UI:136
save UI:63, C:27, C:546
save individual page C:454
seasonal indicators C:624
set active workfile and page C:459, C:551
snapshot C:551
sorting UI:323, C:495
stacking UI:315, C:460
start date of observation interval C:622
statistics UI:63
storage defaults UI:2099
storage precision and compression UI:2099
structure settings UI:282
structuring UI:271
summary view UI:63
time trend C:624, C:628, C:629
time trend (calendar based) C:624
undated UI:273
unstacking UI:309, C:466
window UI:48
workfile C:553
World Bank C:349
World Bank data UI:410
@wquery C:600, C:794
Wrapping text C:119
@wreplace C:86, C:682
@wright C:85, C:682
Write UII:1860
coef vector to file O:31
data to text file C:554
matrix to text file O:467
pool data to text file O:552
rowvector to text file O:574
sym to text file O:802
vector to text file O:989
write C:554, O:31, O:467, O:552
rowvector O:574
sym O:802
vector O:989
@wsort C:88, C:683
@wsplit C:90, C:683
wtsls O:843
@wunion C:87, C:683
@wunique C:87, C:684
