Object Reference : Object Command Summary : H
H
HAC
cointegrating regression UII:1173
GMM estimation UII:984, C:380, O:112
panel cointegrating regression 1:1977
robust standard errors UII:926, UII:939, C:306, C:423, C:509, O:56, O:130, O:183
system GMM UII:1625
Hadri UII:1565, C:517, O:675
Hannan-Quinn criterion UII:2147
equation data member O:38
for equation UII:909
system data member O:807
VAR data member O:907
Hansen instability test UII:1181, O:67
Harmonic mean C:575, C:610
Harvey heteroskedasticity test UII:1092, O:119
@hasoption C:143
Hat matrix UII:1125, O:124
Hatanaka two-step estimator UII:1037
Hausman test UII:1129, UII:1947, O:163, O:536
Haver Analytics data UI:395
Haver Analytics Database C:349
convert to EViews database C:386
display series description C:389
fetch series from C:387
@hcat C:722
hconvert C:386
heckit C:385
Heckit modelSee Heckman selection
Heckman selection UII:1267
example UII:1270
ML estimation UII:1268
performing in EViews UII:1269
two-step model UII:1267
Heckman two-step UII:1267
Help UI:8, UI:98
EViews Forum UI:9, UI:98
help system UI:8
World Wide Web UI:98
help C:387
Hessian matrix
user defined optimization 1:247, 1:255, C:433, C:434
Heteroskedasticity O:119
binary models UII:1245
cross-sectional details UII:1882
groupwise UI:617
of known form UII:941
period details UII:1882
quantile slope test O:159
tests of UII:1091, O:119
White test in VAR O:964
White's test UII:1093
wizard UII:1094
Heteroskedasticity consistent covariances UII:930
finite sample C:423, O:130
hetttest O:119
Heywood cases UII:2050
hfetch C:387
Hide
objects in spool UI:845
hide O:711
High frequency data UI:33
High-breakdown estimation 1:1322
High-low-open-close graph UI:714, O:1020
Hildreth-Lu UII:1037
hilo O:1020
hist C:388, O:121, O:624
Histogram UI:426, C:388, O:624, O:1007
as axis UI:663
average shifted graph UI:728
bin width UI:724
edge polygon graph UI:727
equation residuals O:121
graph UI:723
normality test UII:1088
polygon graph UI:726
save data UI:571, O:610
variable width UI:720, O:1054
Historical decomposition UII:1655
History
command window UI:92
field in database query UI:347
hlabel C:389
@hmean C:575, C:610
Hodrick-Prescott filter UI:566, UI:567, C:389, O:624
@holiday C:626
Holiday variables C:626
Holt-Winters C:490, O:663
additive UI:542
ETS framework UI:548
likelihood based UI:548
multiplicative UI:542
no-seasonal UI:543
Honda random effects test UII:1949, O:163
horizindent O:711
Horizontal matrix concatenation C:722
Hosmer-Lemeshow test UII:1238, UII:1284, O:180
@hour C:113, C:493, C:624
@hourf C:113, C:493, C:624
hpf C:389, O:624
HTML UI:837
open page as workfile UI:36, C:530
save table as C:66
save table as web page UI:837
save table to file O:858
save text object to file O:885
Huber covariance 1:1324, O:169
Huber function 1:1319
Huber M-estimator 1:1317, 1:1318, O:170
Huber/White standard errors UII:1283, UII:1292, C:297, C:303, C:304, C:311, C:339, C:340, C:376, C:385, C:423, C:428, C:438, C:504, O:44, O:52, O:61, O:62, O:83, O:108, O:118, O:130, O:146, O:151, O:177, O:428, O:746, O:812, O:822, O:958
Hypothesis test
stability UII:1385, UI:1415
Hypothesis tests
See also Test.
ARCH UII:1092
Bartlett test UI:440
BDS independence UI:452, UII:1579
binomial sign test UI:434
Brown-Forsythe UI:441
chi-square test UI:438
Chow breakpoint UII:1100
coefficient based UII:1070
coefficient p-value UII:906
CUSUM UII:1120
CUSUM of squares UII:1121
demonstration UI:18
descriptive statistic tests UI:432
distribution UI:441
F-test UI:440
heteroskedasticity UII:1091
irrelevant or redundant variable UII:1084
Kruskal-Wallis test UI:439
Levene test UI:441, O:670
mean UI:432
median UI:434
multi-sample equality UI:435
nonnested UII:1131
normality UII:1088
omitted variables UII:1083
Ramsey RESET UII:1118
residual based UII:1087
Siegel-Tukey test UI:440
single sample UI:432
stability test UII:1099
unit root UI:451, UII:1519
unknown breakpoint UII:1102
Van der Waerden test UI:434, UI:439
variance UI:433
Wald coefficient restriction test UII:1076
White heteroskedasticity UII:1093
Wilcoxon rank sum test UI:438
Wilcoxon signed ranks test UI:434, O:671
