L
Label
label
O:12,
O:24,
O:125,
O:215,
0:254,
O:301,
O:370,
O:408,
O:425,
O:452,
O:487,
O:526,
O:566,
O:578,
O:585,
O:627,
O:714,
O:740,
O:762,
O:768,
O:793,
O:828,
O:857,
O:884,
0:892,
O:900,
O:936,
O:981 Lag
VAR lag order selection
O:937Lag length
Lag operator C:571
Lag structure
Lagged dependent variable
Lagged dependent variable models
Lagrange multiplier
test for ARCH in residuals
O:119Laplace distribution C:594
Laplace function
CDF C:606
density C:608
inverse CDF C:616
random number generator C:617
Last non-missing
matrix columns index
C:696row-wise C:587, C:617
row-wise index C:587, C:617
vector or series index
C:723Last_update
field in database query
UI:347Last_write
UI:347@lastsby C:588
Latent variable
LaTeX
Lead
Least squares
Legend
appearance and placement
O:302Length
Less than comparison
C:275matrix element by element
C:716Less than or equal to comparison
C:716Leverages
estimation in presence of high
1:1317Line break (programs)
C:120Line numbers
Linear
Linearity tests
create by copy-and-paste
UI:118List
Litterman
Litterman/Minnesota prior
O:913LM test
Load
Local
@log C:569, C:611
Log likelihood
for regression (normal errors)
UII:908Log normal function
CDF C:606
density C:609
inverse CDF C:616
@log10 C:570, C:611
Logarithm
arbitrary base C:570, C:612
base-10 C:570, C:611
difference C:571, C:609
natural C:569, C:611
Logistic
distribution C:594
logit function C:591
CDF C:606
density C:609
inverse CDF C:616
@logit C:591
append specification line
O:419check user-supplied derivatives
O:421coefficient covariance
O:422Log-normal distribution C:594
@logx C:570, C:612
panel cointegrating regression
1:1977Long-run relationships
Loop
for (control variables)
C:146for (string variables)
C:149export coef vector to file
O:31export matrix to file
O:467export pool data to file
O:552export rowvector to file
O:574export vector to file
O:989
