T
add comment to cell
O:849assigning numbers to cells
C:58assigning strings to cells
C:58assignment with formatting
C:59convert from matrix
C:751copy range of cells
O:850copy table to new table
C:505copy to other windows programs
UI:836create using freeze
C:368creating by freezing a view
C:57delete cells from a table
O:852fill (background) color for cells
O:861insert cells into a table
O:855insert table in new table
C:505paste as unformatted text
UI:837read data from foreign source
UI:838set and format cell contents
C:486Tabs
Tabulation
@tan C:592, C:619
Tangent C:592, C:619
t-distribution C:595
t-distribution function
CDF C:607
density C:609
inverse CDF C:616
random number generator C:618
Template
Test
See also Hypothesis tests, Specification test and Goodness of fit
for equality of matrix values
C:713for equality of values C:568, C:609
for inequality of matrix values
C:718for inequality of values C:568, C:614
for missing value C:568, C:611
for serial correlation in VAR
O:911heteroskedasticity in VAR
O:964Johansen cointegration from a VAR
O:917lag exclusion (Wald)
O:960mean, median, variance equality
O:401mean, median, variance equality by classification
O:670Park added variable test
O:67redundant fixed effects
O:95simple mean, median, variance hypotheses
O:671unit root (seasonal)
O:643Text file
Text object
@theil C:577
Theoretical distribution graph
UI:733Thresold regression
O:181Time
Time series functions
UI:191, C:570, C:572Trace
TRAMO/SEATS
Transition results
coefficient from regression
C:578, C:619,
C:708,
C:750intercept from trend regression C:575
@trigamma C:592
Trigonometric functions C:592
Trimmed mean C:578, C:620
Mean
@trrendcoef C:578, C:619,
C:750 tsls
t-statistics
retrieve from system
O:807Tukey-Hamming kernel
panel cointegrating regression
1:1977Tukey-Hanning kernel
1:1977Tukey-Parzen kernel
1:1977Tuning constants
Two-stage least squares
See 2sls (Two-Stage Least Squares).
Type
field in database query
UI:345
