R
Random effects
Random number
generators C:592
Rank condition for identification
UII:965Ranks
observations in series or vector
UI:194, C:577, C:616@rate C:573, C:616
Rate for annuity C:573, C:616
Ratio to moving-average
UI:523RATS data
@rbeta C:616, C:617
@rbinom C:616
@rchisq C:616
data from foreign file into coef vector
O:25data from foreign file into matrix
O:460data from foreign file into pool
O:536data from foreign file into rowvector
O:567data from foreign file into sym
O:795data from foreign file into vector
O:982Reading EViews data (in other applications)
UI:164,
C:179Reciprocal C:569, C:611
Recode
matrix element by element
C:719@recode C:570, C:616
Recode values C:569, C:570, C:610, C:616
Recording user actions
C:3Rectangles
Recursive estimation
Redundant fixed effects test
O:95Regression
t-statistic for coefficient
UII:906Regressors
make group containing from equation
O:140Relational operators
Remarks
field in database query
UI:347Reorder
columns of a matrix using vector of ranks
C:736rows of a matrix using vector of ranks
C:694,
C:701Replacement variable
C:133Representations view
Reproduced covariance
O:206Residuals
censored dependent variable models
UII:1258covariance matrix (pool)
O:540covariance matrix of in system
O:836covariance matrix of in VAR
O:951display of in sspace
O:749display of in system
O:836estimation in presence of large
1:1317from two stage least squares
UII:966Resize
Restricted VAR
clear restriction text
O:916set restriction text
O:909Results
Reverse sweep operator
C:740@rexp C:617
@rfdist C:617
@rfirst C:587, C:617
@rgamma C:617
@RGB specification of colors
0:250,
0:258,
0:265,
0:267,
O:274,
O:278,
O:280,
O:284,
O:288,
O:295,
O:298,
O:303,
O:311,
O:319,
O:327,
O:354,
O:359,
O:387,
O:396,
O:652,
O:661,
O:862@rged C:617
@rifirst C:587, C:617
@rilast C:587, C:617
@rimax C:587, C:617
@rimin C:587, C:617
@riwish C:617
@riwishc C:617
@riwishi C:617
@riwishic C:617
@rlaplace C:617
@rlast C:587, C:617
@rlogistic C:617
@rlognorm C:617
@rmax C:587, C:617
@rmean C:586, C:617
@rmin C:587, C:617
@rmnorm C:617
@rmnormc C:608, C:609, C:617, C:618
@rmnormi C:617
@rmnormic C:617
@rmse C:577
@rnas C:586, C:618
@rnegbin C:618
@rnorm C:618
Rn-squared statistic
@robs C:586, C:618
Robust regression
Bollerslev-Wooldridge for GARCH
UII:1144Rolling regression
user object example
1:226Roots of the AR polynomial in VAR
O:912Rotate
Round C:569, C:570, C:606, C:610, C:618
@round C:570, C:618
Roundoff error in for loops
C:779Row
functions See Row statistics.
Row statistics C:585
first non-missing obs C:587, C:617
first non-missing obs index C:587, C:617
last non-missing obs C:587, C:617
last non-missing obs index C:587, C:617
maximum C:587, C:617
maximum index C:587, C:617
mean C:586, C:617
minimum C:587, C:617
minimum index C:587, C:617
NAs, number of C:586, C:618
observations matching value, number of C:586, C:618
Observations, number of C:586, C:618
standard deviation C:586, C:618
sum C:586, C:618
sum of squares C:587, C:618
variance C:586, C:587, C:618
filled rowvector function
C:720@rpareto C:618
@rpoisson C:618
R-squared
UII:967retrieve from equation
O:38retrieve from system
O:806@rstdev C:586, C:618
@rstdevp C:586, C:618
@rstdevs C:586, C:618
@rsum C:586, C:618
@rsumsq C:587, C:618
@rtdist C:618
save text object to file
O:885application in batch mode
C:126@runif C:618
@rvalcount C:586, C:618
@rvar C:586, C:618
@rvarp C:587, C:618
@rvars C:587, C:618
@rweib C:618
@rwish C:618
@rwishc C:618
@rwishi C:618
@rwishic C:618
Rw-squared statistic
