Object Reference : Object Command Summary : E
E
Easy query UI:342
ec O:922
ECB C:349
Economy.com UI:400
EcoWin database UI:376, C:349
edftest O:612
Edit
group UI:135
series UI:131, UI:577
table UI:829
@ediv C:713, C:717
EDO (EViews Database Objects) C:180
EDX interface C:189
@eeq C:713
@eeqna C:713
EGARCH UII:1151, C:295, O:42
See also GARCH
@ege C:714
EGLS (estimated GLS) UII:1865, UII:1883, UII:1917
@egt C:714
EHS test UII:987, O:152
EIA (U.S. Energy Administration) C:349
EIA (U.S. Energy Administration) data UI:380, C:349
Eigenvalues C:715, O:203, O:784
factor analysis UII:2057
plots UI:622
@eigenvalues C:715
Eigenvectors C:715
@eigenvectors C:715
Elapsed time C:511, C:782
Elastic net
coefficient and lambda matrix O:66
coefficient graphs O:66
training and test measures O:85
Elasticity at means UII:1070, O:67
@ele C:716
@elem UI:190, C:621
Element
assign in matrix C:262
Element by element
bounds C:693
division C:713, C:717
equality C:713
greater than C:714
greater than or equal to C:714
inequality C:718
inverse C:715
Less than C:716
less than or equal to C:716
matrix functions C:690
maximum C:717
minimum C:717
raise to power C:718
recode C:719
sign C:743
@elim C:716
Elimination matrix C:716
Elliot, Rothenberg, and Stock point optimal test UII:1527, C:518, O:676
See also Unit root tests.
Ellipse
adding to a graph O:277
else C:763
Else clause in if statement C:145, C:146, C:763
@elt C:716
@emax C:717
Embedded spools UI:842
@emin C:717
Empirical CDF O:1007
graph UI:734
Empirical distribution tests UI:441, O:612
Empirical quantile graph UI:736
Empirical survivor graph UI:735
Empty string C:653
Encrypted program file C:123
End field UI:52, UI:346
@enddate C:622
endif C:764
endog O:484, O:737, O:820, O:925
Endogeneity UII:1129
test of UII:987, O:88
Endogenous variables UII:963
dropping from models O:483
in models UII:1779
make series or group in model O:488
make series or group in state space O:741
make series or group in system O:830
make series or group in VAR O:942
of specification O:484, O:737
of specification in system O:820
of specification in VAR O:925
replacing in a model O:495
endogtest O:88
endsub C:764
@eneq C:718
@eneqna C:718
enet (Elastic Net) C:354, O:89
Engle-Granger cointegration test UII:2032, O:67
Enter data from keyboard C:343
Enterprise Edition UI:356, UI:357, UI:367, UI:375, UI:376, UI:390, UI:396, UI:400, C:346, C:349
@env C:764
Epanechnikov kernel UI:730
@epow C:718
@eqna C:83, C:568, C:609, C:652
@eqnq UI:196
eqs O:484
Equality tests UI:435
groups UI:617
mean UI:436
median UI:438
variance UI:440
@equaloption C:143
Equals comparison C:275
matrix element by element C:713
Equation UII:899, O:33
add to model UII:1784
ARDL cointegration O:80
attribute setting O:171
automatic dummy variables in UII:922
coefficient covariance matrix UII:911, O:39, O:65
coefficient covariance scalar UII:910, O:39
coefficient p-values vector UII:911
coefficient standard error vector UII:911, O:40
coefficient t-statistic scalar UII:911, O:39
coefficient t-statistic vector UII:911, O:40
coefficient vector UII:911, UII:914, O:39
command string UII:911
create UII:899
data members UI:58, O:37
declare O:91
derivatives UII:913, O:86
display gradients O:117
estimating in models UII:1783
functional coefficients O:103
functional coefficients bandwidth O:98
functional coefficients bias O:98
functional coefficients confidence interval O:101
functional coefficients correlation O:102
functional coefficients covariance O:101, O:102
functional coefficients testing O:103
gradients UII:913
methods O:33
procedures UII:913
procs UI:61, O:36
regression coefficients UII:905
regression summary statistics UII:907
residuals UII:914
results UII:905
retrieve previously estimated UII:914
r-squared UII:907, O:38
sample string UII:911
saved results UII:910
scalar results UII:910
specification UII:900
specification by list UII:900
specify by formula UII:901
specify with non-default coefs UII:903
specify with restrictions UII:902
specify without dependent variable UII:902
specifying a constant UII:900
stepwise regression C:499, O:172
store UII:914
text representation UII:912
t-statistic UII:906
updatetime UII:911
vector and matrix results UII:911
views UI:60, UII:912, O:34
equation O:91
Equation view
of model O:484
@erecode C:719
@erf C:590
@erfc C:591
Ergodic probabilities 1:1440, 1:1446, UI:1733, O:176, O:957
errbar O:1018
Error bar graph UI:714, O:1018
Error correction model
See VEC and VAR.
Error function C:590
complementary C:591
@errorcount C:765
Errors
codes in programs C:771
control C:152
count in programs C:762, C:765
handling in programs C:152
maximum number in programs C:773, C:778
message in programs C:771
number in programs C:777
Error-trend-seasonal smoothing
See ETS smoothing
Estimation UII:903
See also Estimation methods
as part of model UII:1783
auto-series UI:205
behavior UII:2139
binary dependent variable UII:1229
censored models UII:1254
cointegrating regression C:323, O:72
collinearity UII:916
convergence UII:2139
convergence problems UII:2127, UII:2128
count models UII:1274
demonstration UI:15
derivative computation options UII:2129
derivatives UII:2142
failure to improve UII:2127
for pool UII:1862
GLM UII:1289
GMM UII:975
log likelihood UII:1502
logl UII:1502
missing data UII:904
multi-equation UII:1590
near singular matrix problems UII:2129
nonlinear least squares UII:945
options UII:2125
ordered models UII:1247
output UII:905
panel UII:1915
residuals from equation UII:914
robust regression 1:1325
sample UII:903
sample adjustment UII:904
single equation methods UII:903
starting values UII:2127
state space UII:1757, UII:1768
systems UII:1590, UII:1598
truncated models UII:1263
two-stage least squares UII:963
user-defined I:861, 1:243, C:431
VAR UII:1633, UII:1639
VEC UII:1670
Estimation methods
2sls C:507, C:512, O:186, O:545, O:840
3sls O:808
ARMA C:421, O:128
for factor O:197
for pool O:510
for system O:805
for var O:905
generalized least squares C:421, C:427, O:128, O:145, O:527, O:829
GMM C:378, O:110, O:824
least squares C:385, C:421, C:427, O:118, O:128, O:145, O:527, O:829, O:913, O:938
maximum likelihood O:220, O:417, O:428, O:745
nonlinear least squares C:385, C:421, C:427, O:118, O:128, O:145, O:527, O:829, O:913, O:938
stepwise C:499, O:172
Estimation methods
enet C:354, O:89
ets O:614
ETS smoothing UI:545, O:614
AMSE based UI:552
example UI:558
forecast O:616
forecast details UI:554, UI:556
initial states UI:551
MLE based UI:552
model selection UI:553, UI:556
output UI:557
parameters UI:551, UI:556
performing in EViews UI:554
specification UI:555
technical details UI:546
Euler’s constant C:591
Eurostat database C:349
Eurostat SDMX UI:385
Evaluating forecasts UI:452, O:619
Evaluation order UI:188
logl UII:1499
@event C:626
Event functions C:626
EViews
add-ins directory C:762
auto-update UI:7, UI:98, UI:2109
installation directory C:766
spawn process C:496
version number C:791, C:792
EViews database C:349
EViews Database Extension (EDX) interface C:189
EViews Databases UI:325
EViews Enterprise Edition UI:376, UI:390, UI:395, UI:400, C:346, C:349
EViews Forum UI:9, UI:98
@evpath C:766
Examining data
demonstration UI:8
Excel
Add-in UI:164, C:180
reading EViews data in UI:164, 1:865
Excel file C:530, C:554
export coef vector to file O:31
export data to file C:546, C:547, C:554
export matrix to file O:467
export pool data to file O:552
export rowvector to file O:574
export sym to file O:802
export vector to file O:989
importing data into coef vector O:25
importing data into matrix UI:161, C:400, O:446, O:460, O:560, O:787, O:975
importing data into pool O:536
importing data into rowvector O:567
importing data into sym O:795
importing data into table UI:161, UI:838, C:407
importing data into vector O:982
importing data into workfile UI:150, C:390, C:474
linking data from UI:43
opening as workfile UI:36
opening as workfile demo UI:5
retrieve sheet names C:780
saving as UI:161
exclude O:484
Exclude variables from model solution O:484
exec C:154
Execute program C:123, C:356, C:483
abort C:126
with arguments C:138, C:141, C:143
Exit
from EViews C:358
loop C:153, C:766
subroutine C:775
exit C:358
exitloop C:766
Exogenous variable UII:963
in models UII:1779
uncertainty UII:1815, UII:1826
@exp C:569, C:610
exp C:569, C:610
@expand UI:208, UII:922, C:632
Expectation-prediction table O:154
binary models UII:1236
ordered models UII:1250
Expectations consistency in models UII:1817
Expected dependent variable
censored models UII:1259
truncated models UII:1265
Expected latent variable
@explode C:719
Exponential
distribution C:593
function C:569
Exponential function C:610
CDF C:606
density C:608
inverse CDF C:616
random number generator C:617
Exponential GARCH (EGARCH) UII:1151, C:295, O:42
See also GARCH
Exponential regression UII:1288
Exponential smoothing UI:539, UI:545, C:490, O:614, O:663
See also ETS smoothing
See also Smoothing.
double UI:541
Holt-Winters additive UI:542, C:491, O:664
Holt-Winters multiplicative UI:542, C:491, O:664
Holt-Winters no seasonal UI:543, C:491, O:664
single UI:541
Export UI:163, UI:323, C:454
coef vector O:31
database UI:333
matrix C:281, O:467
pool data UII:1860, O:552
rowvector O:574
sym O:802
tables C:66
vector O:989
workfile data C:454, C:546, C:554
Expression UI:187
for database fields UI:345
parentheses UI:188
Extending EViews
See Add-ins.
External program C:181, C:496
Extract
row vector C:738, C:739
submatrix from matrix C:747
extract O:709, 0:892
Extreme value
binary model UII:1230
censored dependent variable models UII:1255
distribution C:593
