Object Reference : Object Command Summary : M
M
ma C:634
MA roots
inverted UII:1020
MA specification C:634
backcasting UII:1014
forecast UII:1057
in ARIMA models UII:995, UII:1008
in model solution UII:1817
in two stage least squares UII:969
seasonal C:639
Macro-recording C:3
MADMED
definition 1:1320
MADZERO
definition 1:1320
MAE UI:453
@mae C:575, C:612
Magellan C:349
Main diagonal C:722
Make model object O:140, O:427, O:531, O:742, O:832, O:942
makeattrser 0:256
makecoint O:941
@makedate C:107, C:656
makederivs O:136
@makediagonal C:727
makeendog O:488, O:741, O:830, O:942
makefilter O:741
makegarch O:138, O:830
makegrads O:139, O:426, O:742
makegraph O:488
makegroup O:304, O:490, O:530
makelimits O:139
makemap O:13
makemodel O:140, O:427, O:531, O:742, O:832, O:942
makepanpcomp O:630
makepcomp O:373
makeregs O:140
makeresids O:141, O:531, O:743, O:832, O:943
makergmprobs O:142, O:943
makesignals O:743
makestates O:744
makestats O:532
makesystem O:375, O:533, O:945
maketransprobs O:143, O:945
@makevalidname C:773
Mann-Whitney test UI:438, O:670
@map UI:236
map O:14, O:633
MAPE UI:453
@mape C:575, C:612
Maps
geographic UI:645
Marginal significance level UII:906, UII:1069
Markov switching 1:1435, 1:1437, C:502, O:175
AR 1:1441, 1:1442
autoregressive models 1:1441, 1:1442
dynamic regression 1:1441
estimation in EViews 1:1443
example 1:1455
expected durations 1:1451, UI:1737, O:143, O:176, O:185, O:945, O:957, O:961
filtering 1:1438
initial probabilities 1:1440, 1:1446, UI:1733, O:176, O:957
mean models 1:1441
regime probabilities 1:1438, 1:1453, 1:1454, UI:1726, UI:1738, UI:1740, O:142, O:166, O:943, O:953
smoothing 1:1439, UI:1730
transition probabilities 1:1451, UI:1737, O:143, O:176, O:185, O:945, O:957, O:961
transition results 1:1451, 1:1454, UI:1737, UI:1739, O:143, O:176, O:185, O:945, O:957, O:961
VAR UI:1723
views available 1:1451, UI:1736
Markov switching VAR O:956
MSI-VAR(2) example UI:1740
Marquardt UII:2133
mask 0:257
Match merge UI:242, O:409
by date UI:247
many-to-many UI:245
many-to-one UI:244
one-to-many UI:243
panels UI:249
using links UI:242
Match operator in database query UI:345
Match-merge
as import UI:155
Mathematical functions C:569
Matlab I:861, C:182
matplace C:728
Matrix C:750
assign values C:262
attribute setting O:462
Cholesky factorization C:695
column headers O:462
column product C:706
column quantiles C:706
column standard deviation C:707
column trimmed mean C:708
column variance C:709, C:710
columns, number of C:702
condition number C:703
convert to other matrix objects C:282
convert to/from series or group C:269, O:330, O:589
copy C:266
copy submatrix C:267
covert from series or group (drop NAs) C:704, C:745
covert from series or group (keep NAs) C:746
covert from table C:751
cumulative product C:699, C:709
cumulative sum C:699
data members O:435
declare C:261, O:455
demean C:710
demean columns C:700
descriptive statistics O:467
detrend C:711
detrend columns C:694, C:700
element bounds C:693
element division C:713, C:717
element equality C:713
element greater than C:714
element greater than or equal to C:714
element inequality C:718
element inverse C:715
element less than C:716
element less than or equal to C:716
element maximum C:717
element minimum C:717
element power C:718
element recode C:719
element sign C:743
elementwise operations C:277
export data C:281
extract row C:738, C:739
fill values C:720, O:445, O:617
fill with values C:263
generalized inverse C:733
graph views O:434
import data C:281
indentation O:464
initialize O:445
main diagonal C:722
norm C:731
objects C:261
of ones C:732
outer product C:732
percentiles C:576, C:615, C:700, C:733
permute columns of using vector of ranks C:736
permute rows of C:733
permute rows of using vector of ranks C:694, C:701
place submatrix C:728
place vector in column C:700
place vector into C:738
procs O:435
QR decomposition C:734
quadratic form C:734
random normal C:729, C:731, C:737
random uniform C:730, C:738
rank C:734
ranks of the elements of the matrix C:735
resample rows from C:736
reverse sweep operator C:740
row headers O:465
rows, numbers of C:739
rows, sort C:740
scale rows or columns C:741
singular value decomposition C:747, C:748
spreadsheet view O:466
stack columns C:755
stack lower triangular columns C:755
standardize C:744
standardize (population) C:745
columns C:703
standardize columns of matrix C:702
subtract submatrix C:747
sweep operator C:749
trace C:750
trend C:743
trend coef C:750
trend coef for columns C:708
trend for columns C:706
unique values C:752
vertical concatenation C:754
views C:280, O:434
matrix O:455
Matrix commands and functions
column means C:282
column scaling C:282
column summaries C:278
commands C:279
descriptive statistics C:278, C:691
difference C:278
element C:276, C:690
functions C:278
matrix algebra C:277, C:689
missing values C:279
utility C:276, C:687
Matrix concatenation C:722
Matrix cumulative sum C:709
Matrix operators
addition (+) C:273
and loop operators C:281
comparison operators C:275
division (/) C:275
multiplication (*) C:274
negation (-) C:273
order of evaluation C:273
subtraction (-) C:274
@mav C:584, C:612
@mavc C:584, C:612
@max C:576, C:612
@maxerrs C:773
@maxes C:576, C:612, C:729
Maximal values C:729
Maximization
See also Optimization (user-defined).
Maximization See Optimization (user-defined).
Maximum C:576, C:612
by category C:588, C:612
cumulative C:579, C:581, C:607
index C:575
matrix columns C:697
matrix columns index C:696
matrix element by element C:717
moving C:583, C:585, C:613
n-largest numbers C:576
number of observations UI:2107
row-wise C:587, C:617
row-wise index C:587, C:617
Maximum absolute correlation O:219
Maximum likelihood O:428, O:745
See also Logl.
factor O:220
full information UII:1592
logl O:417
quasi-generalized pseudo-maximum likelihood UII:1281, UII:1299
quasi-maximum likelihood UII:1276, UII:1287
state space O:729
user specified UII:1495
@maxsby C:588, C:612
McFadden R-squared UII:1232
@mcor C:585, C:612
@mcov C:584, C:612
@mcovp C:585, C:612
@mcovs C:584, C:612
Mean UI:427, C:576, C:612
cumulative C:578, C:580, C:607
equality test UI:436, O:401, O:670
geometric C:575, C:610
harmonic C:575, C:610
hypothesis test of UI:432
moving C:582, C:584, C:612, C:613
row-wise C:586, C:617
trimemd C:578, C:620
@mean C:576, C:612
Mean absolute error UI:453, UII:1052, C:575, C:612
Mean absolute percentage error UI:453, UII:1052, C:575, C:612
Mean equation (GARCH) UII:1141
Mean square error UI:534, UI:554, UII:1052, C:576, C:614
means O:145
@meansby C:588, C:612
Measurement equation UII:1754
Measurement error UII:963, UII:1118
Median UI:427, C:576, C:612
Cumulative C:580, C:581
equality test UI:438, O:401, O:670
hypothesis test of UI:434
matrix columns C:698
@median C:576, C:612
Median function 1:1319
@mediansby C:588, C:612
members 0:893
Memory allocation UI:2107
Memory, running out of UI:2107
Menu UI:114
objects UI:115
Merge UI:118
See Match merge.
graph objects O:299, O:304, O:491
graphs UI:106, C:37
into model O:304, O:491
into panel workfiles UII:1911
panel data C:336
store option UI:331
using links O:409
merge O:304, O:491
Messages UI:2089
model solution O:492
M-estimation 1:1317, O:170
performing in EViews 1:1325
tuning constants 1:1318, O:170
weight functions 1:1318, O:170
Meta data
See Attributes
Metafile
save graph as Windows metafile. UI:825
Micro TSP
opening workfiles UI:323
Microsoft Excel
See Excel.
Microsoft PowerPoint
pasting graphs and data into 1:865
Microsoft Word
@mid C:85, C:657
MIDAS
Almon weighting II:1211
beta weighting II:1212, II:1213
example II:1219
exponential Almon weighting II:1212
PDL weighting II:1211
regression II:1209, C:427, O:145
step weighting II:1211
VAR O:947
@min C:576, C:612
Minimization
Minimization See Optimization (user-defined).
Minimum C:576, C:612, C:613
by category C:588, C:613
index C:575
n-smallest numbers C:576
Minimum discrepancy UII:2077
@minner C:585, C:612
@mins C:576, C:613
@minsby C:588, C:613
@minute C:113, C:624
Missing values UI:195, C:279, C:568, C:611
code for missing C:635
forecasting UII:1049
handling in estimation UII:904
in frequency conversion UI:172
in models UII:1830
in observation graphs UI:664
interpolate UI:469, O:626
mathematical functions C:569
number of C:576
recoding UI:197, C:570, C:614
relational comparisons involving UI:195
test UI:196
mixed O:1026
Mixed data sampling
Mixed frequency
VAR O:947
Mixed frequency graph UI:672
Mixed frequency VAR UI:1711
Mixed line graph UI:711, O:1026
@mkurt C:585, C:613
ml O:220, O:428, O:745
MLE
See Logl
@mmax C:585, C:613
MM-estimation 1:1324
@mmin C:585, C:613
@mnas C:585, C:613
@mobs C:585, C:613
@mod C:569, C:613
Mode C:138
Model
excluding variables UII:1811
overriding variables UII:1810
scenario list O:500
model O:492
Model (object) O:470
data members O:471
declare O:492
procs O:470
See Models.
views O:470
Model averaging UI:533, O:618
Model consistent expectations UII:1817
Model selection
ARDL models II:1196
ARIMA models UI:524
ARIMA using X-13 UI:479, UI:482, O:693, O:696
ETS smoothing UI:553, UI:556
TAR estimation UI:1364, C:508, O:181
Models
add factor assignment and removal O:473
add factor initialization O:474
add factors UII:1779, UII:1792, UII:1812
adding equations UII:1784
aliasing UII:1781, UII:1809
append specification line O:477
attribute setting O:500
binding variables UII:1781
block structure UII:1802, O:478
boundaries UII:1827
break all model links O:507
Broyden solution UII:2136
Broyden solver UII:1828
coefficient uncertainty UII:1799, UII:1815, UII:1825
comparing solutions UII:1836, O:480
convergence test UII:1830
creating UII:1797
definition UII:1589
demonstration UII:1243
dependency graph UII:1806, O:486
derivatives UII:1830
diagnostic messages and iteration history UII:1826
display model check boundaries view O:478
dropping endogenous variables O:483
dropping linked objects O:483
dynamic solution UII:1820
dynamic solve UII:1787
editing scenario data O:476
editing scenarios UII:1810
endogenous variables UII:1779
equation view UII:1799, O:484
estimating equations UII:1783
exclude variables from solution O:484
excluding variables UII:1808
exogenous variable UII:1779
exogenous variable uncertainty UII:1815, UII:1826
Fair-Taylor solution UII:1816
fit option for solution UII:1821
forecasting with UII:1788
future values UII:1815
Gauss-Seidel solution UII:2134
Gauss-Seidel solver UII:1827
handling of ARMA terms UII:1821
identities UII:1780
initialize excluded variables UII:1828
inline equations UII:1798
intercept shift add factor UII:1812
linked equations UII:1798
MA error terms UII:1817
make from equation object O:140
make from logl object O:427
make from pool object O:531
make from sspace object O:742
make from system object O:832
make from var object O:942
make graph of model series O:488
make group of model series O:490
merge into O:304, O:491
missing value handling UII:1830
Newton solution UII:2135
Newton’s method UII:1828
options for solving O:503
options for stochastic simulation O:486
options for stochastic solving O:505
override add factors O:475
overrides in model solution O:493
overriding variables UII:1781, UII:1809, UII:1815
print view O:494
properties of equations UII:1800
reincluding variables O:495
replacing endogenous variables O:495
replacing linked objects O:496
replacing variables O:497
reverting variables to initial values O:497
roundoff of solution UII:1831
scenarios UII:1243, UII:1795, UII:1808, O:498
scenarios (example) UII:1243
simultaneous and recursive blocks UII:1802
solution messages O:492
solution methods UII:1827
solve C:494, O:502
solve (dynamic) UII:1787
solve (static) UII:1785
solve control to match target O:481
solving UII:1814
solving to match target UII:1831
starting values UII:1830
static solution UII:1821
static solve UII:1785
stochastic equations UII:1780
stochastic simulation UII:1820
stochastic solution UII:1822
text description of UII:1803, UII:1804
text keywords UII:1803, UII:1804
text representation O:506, O:887
trace endogenous O:501
trace iteration history O:506
track O:507
tracking variables UII:1826
update specification O:508
updating links UII:1799
variable dependencies UII:1802
variable shift add factor UII:1812
variable view UII:1801, O:509
Modulus C:569, C:613
Moment condition UII:976
Moment selection criteria UII:989
@month C:113, C:493, C:623
Moody’s Economy.com C:349
Moody’s Economy.com data UI:400
Moore-Penrose inverse of matrix C:733
@movav C:582, C:613
@movavc C:582, C:613
@movcor C:583, C:613
@movcov C:582, C:613
@movcovp C:583, C:613
@movcovs C:582, C:613
move O:716
movereg O:633
movereg O:633
MoveReg decomposition UI:500
Moving average (ARMA) C:634
Moving statistics C:581
average C:582, C:613
average, centered C:584, C:612
centered mean C:582, C:613
correlation C:583, C:585, C:612, C:613
covariance C:582, C:583, C:584, C:585, C:612, C:613
functions UI:193, C:581
geometric mean UI:205
inner product C:583, C:585, C:612, C:613
kurtosis C:585, C:613
maximum C:583, C:585, C:613
mean C:584, C:612
minimum C:583, C:585, C:613
NAs, number of C:583, C:585, C:613
observations, number of C:583, C:585, C:613
skewness C:583, C:585, C:613, C:614
standard deviation C:582, C:584, C:613, C:614
sum C:581, C:583, C:614
sum of squares C:583, C:585, C:614
variance C:582, C:584, C:614
@movinner C:583, C:613
@movkurt C:583, C:613
@movmax C:583, C:613
@movmin C:583, C:613
@movnas C:583, C:613
@movobs C:583, C:613
@movskew C:583, C:613
@movstdev C:582, C:613
@movstdevp C:582, C:613
@movstdevs C:582, C:614
@movsum C:581, C:583, C:614
@movsumsq C:583, C:614
@movvar C:582, C:614
@movvarp C:582, C:614
@movvars C:582, C:614
msa O:223
MSAR 1:1441, 1:1442
MSE UI:534, UI:554, UII:1052
@mse C:576, C:614
msg O:492
MSI 1:1441
@mskew C:585, C:614
MSM 1:1441
@mstdev C:584, C:614
@mstdevp C:584, C:614
@mstdevs C:584, C:614
@msumsq C:585, C:614
mtos C:730
multibreak O:148
Multicollinearity UII:916
coefficient variance decomposition UII:1074
test of UII:1073, UII:1074
Multiple processors UI:2108
Multiplication C:576, C:616
Multiplication operator (*) C:274
Multivariate ARCH UII:1592
Multivariate normal density C:609
Multivariate normal density (Cholesky inverse) C:609
Multivariate normal density (Cholesky) C:609
Multivariate normal density (inverse) C:609
Multivariate normal distribution C:596
Multivariate normal random number generator C:608, C:609, C:617, C:618
Multivariate normal random number generator (Cholesky inverse) C:617
Multivariate normal random number generator (Cholesky) C:617
Multivariate normal random number generator (inverse) C:617
@mvar C:584, C:614
@mvarp C:584, C:614
@mvars C:584, C:614
