Object Reference : Object Command Summary : P
P
PACE UII:2047, O:225
details UII:2078
pace O:225
Pack database UI:352
Packable space UI:328, UI:352
Page
check for existence of C:622
contract C:443
copy from C:444
create new UI:70, C:446
define structure C:463
delete page UI:79, C:452, C:453, C:545
frequency of C:622
number of C:622
order C:545
rename UI:79, C:454
reorder UI:79
resize C:463
retrieve current sample C:622
retrieve ID series C:622
retrieve name of C:622
retrieve names of C:622
save or export C:454
set active C:459
sorting C:495
stack C:460
subset from C:443
Page breaks UI:857
pageappend C:442
pagecontract C:443
pagecopy C:444
@pagecount C:622
pagecreate C:446
pagedelete C:452, C:453, C:545
@pageexist C:622
@pagefreq C:622
@pageid C:622
@pagelist C:622
pageload C:452
@pagename C:622
pagerename C:454
pagesave C:454
pageselect C:459
@pagesmpl C:622
pagestack C:460
pagestruct C:463
pageunlink C:465
pageunstack C:466
Pairwise graphs UI:674
Panel
random components test UII:1949, O:163
residual cross section dependence test O:58, O:604
residual cross-section dependence test UII:1956, II:2018
Panel cointegrating regression 1:1971
equation specification 1:1973
examples 1:1979
performing in EViews 1:1972
PMG models UII:1922
technical details 1:1971, 1:1985
Panel data UII:1891
analysis UII:1912
balanced UI:278
cell identifier UII:1897, C:628
cointegration testing II:2016, UII:2036
convert to pool UI:309
covariance analysis II:1999
create workfile of UI:34
cross-section identifiers UII:1896
cross-section summaries UII:1906
dated UI:277
duplicate identifiers UI:276, UI:293
dynamic panel data UII:1919
estimation See Panel estimation.
fixed effects test UII:1945
frequency conversion UI:253
functions C:628
GMM estimation UII:1919
graphs II:1993
group identifier UII:1896, C:628
Hausman test UII:1947
identifiers UI:274
instrumental variables estimation UII:1918
irregular UI:278
lags UI:275, UII:1899
lags and leads UII:1899
least squares estimation UII:1916
merging data into UII:1911
nested UI:280
period summaries UII:1906
pool comparison UII:1841
regular UI:278
samples in panel workfiles UII:1900
See also Panel workfile.
statistics UII:1904
testing UII:1941
time trend UII:1904, C:628, C:629
trends UII:1904, C:628
unbalanced UI:278
undated UI:277
unit root tests UII:1558, II:2014, C:517, O:401, O:549, O:675
within-group identifier UII:1898, C:628
workfile structure UI:274, C:621
Panel estimation UII:1915, O:33
examples UII:1925
GLS weights UII:1917
GMM UII:1919
GMM (example) UII:1934
GMM details UII:1965
least squares UII:1916
PMG UII:1922
TSLS UII:1918
view effectseffects O:88
Panel unit root See Panel data - unit root tests.
Panel vs. pool UII:1841
Panel workfile
See also Panel data.
create UII:1891
dated UI:288
display UII:1894
functions C:628
nested UI:280
structure UII:1891, UII:1895
undated UI:293
undated with ID UI:292
panelcov O:635
panpcomp O:638
Parallel analysis UII:2047
param C:468
Param (command) UII:951, UII:1598, UII:2128
Parameters C:468
logl UII:1498
PARCH UII:1152, C:296, O:43
Pareto distribution C:595
Pareto function
CDF C:606
density C:609
inverse CDF C:616
random number generator C:618
Park added variable test UII:1184, O:67
Parks estimator UII:1883
partcor O:228
Partial analysis UI:605
Partial autocorrelation UI:449, UII:1000, O:81, O:347, O:608, O:919
Partial correlation O:81, O:228, O:347, O:608, O:919
Partial covariance analysis UI:605, C:341
from group O:348
Partitioned covariance estimation O:225
Parzen kernel
cointegrating regression UII:1173, C:325, C:327, C:328, O:74, O:77, O:78
GMM estimation UII:984, C:380, O:112
long-run covariance estimation UI:635, O:372
panel cointegrating regression 1:1977
robust standard errors UII:939, C:307, C:424, C:510, O:56, O:131, O:184
technical details UII:2153
Parzen-Cauchy kernel
Parzen-Geometric kernel
Parzen-Riesz kernel
Paste UI:118
data as new workfile UI:35
existing series UI:149
into Excel, Word See OLE.
new series UI:148
Paste special
See also OLE.
EViews object 1:870
graphs 1:868
spreadsheets 1:873
tables 1:873
Paste special See OLE.
Path
retrieve workfile path C:622
Payment amount C:573, C:615
@pc C:571, C:615
@pca C:572, C:615
PcGive data UI:395, C:349
@pch C:572, C:615
@pcha C:572, C:615
@pchy C:572, C:615
@pctiles C:576, C:615, C:700, C:733
@pcy C:572, C:615
PDF
save graph as UI:825, 0:259, O:312
save spool as O:720
save table as O:858
PDL
mixed frequencies II:1211
pdl C:637
PDL (polynomial distributed lag) UII:917, UII:1051, C:637
far end restriction UII:918
forecast standard errors UII:1051
instrumental variables UII:919
near end restriction UII:918
specification UII:918
Pearson correlation
from group C:338, O:344
from matrix O:438
from sym O:776
from vector O:970
Pearson covariance UI:600, C:341
from group O:348
from matrix O:441
from sym O:779
panel data O:635
Pedroni panel cointegration test II:2017, UII:2038, C:320, O:341
Percent change
one-period C:571, C:572, C:615
one-period annualized C:572, C:615
one-year C:572, C:615
Percentiles C:576, C:615, C:700, C:733
Period
dummy variable C:624
summaries UII:1906
SUR UII:1884
Period-to-date C:572, C:615
@period-to-date C:572, C:615
Permute
columns of a matrix using vector of ranks C:736
rows of a matrix using vector of ranks C:694, C:701
rows of matrix C:733
@permute C:733
Perron unit root test UII:1531, O:602
Pesaran scaled LM test UII:1956, II:2018, O:58, O:604
Pesaran, Shin and Smith UII:1922
pf O:229
Phillips-Ouliaris cointegration test UII:2032, O:67
Phillips-Perron test UII:1526, C:517, O:401, O:549, O:675
Pi C:592
pie O:1028
Pie graph UI:721, O:1028
@pinverse C:733
plot C:468
PMG UII:1922
@pmt C:573, C:615
PNG UI:825
poff C:774
Point
frequency conversion method UI:173, UI:175, C:334
Poisson count model UII:1274, C:339, O:82
Poisson distribution C:595
Poisson function
CDF C:606
density C:609
inverse CDF C:616
Polynomial distributed lags, See PDL.
pon C:775
Pool UII:1841, O:510
? placeholder UII:1846
add cross section member O:334, O:513
and cross-section specific series UII:1845
AR specification UII:1864
attribute setting O:541
balanced data UII:1852, UII:1856
balanced sample UII:1863
base name UII:1845
coefficient covariance O:516
coefficient test UII:1876
cointegration UII:1858
common coefficients UII:1864
convergence criterion UII:1867
convert to panel UI:315
copy UII:1844
creating UII:1847
cross-section UII:1843
cross-section IDs O:511
cross-section specific coefficients UII:1864
data members O:511
declare O:535
defining UII:1843
defining groups of identifiers UII:1844
delete using identifiers O:519
descriptive statistics UII:1856
dummy variable UII:1855
editing definitions UII:1844
estimation UII:1862
estimation details UII:1877
export data UII:1860
fixed effects UII:1865, UII:1880
generate series UII:1854
generate series using identifiers O:525
group UII:1846
identifier comparison with “?” wildcard C:800
import UII:1848
import data UII:1848
import stacked data UII:1852
instrumental variables UII:1867, UII:1885
make group UII:1859
make group of pool series O:490, O:530
make system UII:1859
members O:510
naming series UII:1845
object UII:1842
options UII:1866
order UII:1851
period-specific coefficients UII:1864
pool series UII:1846
procedures UII:1876
procs O:510
random effects UII:1865, UII:1881
residuals UII:1877
restructure UII:1850
series UII:1846
setup UII:1847
special group identity series UII:1846
specification UII:1843
stacked data UII:1849
tests UII:1876
unstacked data UII:1848
views O:510
workfile UII:1841
pool O:535
Pool data
panel comparison UII:1841
Pool vs. panel UII:1841
Pooled Mean Group estimation UII:1922
Portmanteau test
VAR UII:1648, O:949
Portrait (print orientation) C:23
PostScript UI:825
save graph as PostScript file UI:825
Power (raise to) C:568, C:605
matrix element by element C:718
PowerPoint
pasting graphs and data into 1:865
Prais-Winsten UII:1037
Precedence of evaluation UI:188, C:273
Predetermined variable UII:963
predict O:154
Prediction table O:154
binary models UII:1236
ordered models UII:1250
Present value C:573, C:616
Presentation table O:364
preview C:469
Preview objects UI:107, UI:333
Prewhitening
long-run covariance estimation UII:2159, O:372
system GMM UII:1600, UII:1626
technical details UII:2159
Principal components UI:618, O:378, O:453, O:456, O:630
make scores O:373
panels O:638
Principal factors UII:2077, O:229
iterated O:211
Print
and display C:22
automatic printing C:774, C:775
graphs UI:824
landscape C:23
mode UI:857
objects UI:119
portrait C:23
settings UI:2110
setup options UI:2110
spool UI:857, UI:2111
spool by command C:74
tables UI:836
tables by command C:66
to a spool UI:840
turn off in program C:774
print C:470, O:719
printview O:494
Probability response curve UII:1242
probit C:471, O:154
Probit models UII:1230, C:303, O:52
Procedures UI:103
documentation C:387
Process graphs (quantile regression) UII:1478
Processors
multiple UI:2108
@prod C:576, C:616
Product C:576, C:616
cumulative C:578, C:580, C:607
matrix columns C:706
Program
abort C:126
arguments C:138, C:141, C:143
auto indent UI:2102
backup files UI:2102, C:121
basics C:119
break C:126
call subroutine C:157, C:762
clearing execution errors C:762
command capture C:330
counting execution errors C:765
create C:119
create new file C:471
encrypt C:123
errors C:152
example C:127
exec C:356
execution C:123
execution error code C:771
execution error string C:771
execution option UI:2102, UI:2105, UI:2106
exit loop C:153
for C:146
if C:144
if statement C:144
include file C:154, C:769
ini file C:772, C:776
line comment character C:120, C:129
line continuation character C:120
line numbers C:120
log See Program log.
maximum execution errors C:773
maximum number of execution errors C:778
modes C:138
multiple programs C:153
number of execution errors C:777
open C:123
Options C:143
place subroutine C:159
run C:483
running C:123
save C:121, C:123
snapshots C:121
stop C:126, C:152
stop execution C:780
string object C:92, C:133
strings C:92, C:131
syntax coloring UI:2102
tab settings UI:2102
user-defined dialogs C:165
variables C:130
version 4 compatibility C:138, C:178
while C:150
program C:471
Program log C:139
add message C:419
clear C:415, C:416
save C:420
set log settings C:417
Programming See Program.
Proxy server UI:2106
Pseudoinverse C:733
@psi C:590
@pv C:573, C:616
P-value UII:1069
for coefficient t-statistic UII:906
functions to calculate C:597
Python C:188
