S
Sample
change using for loop
    C:147display sample specification in
    O:582earliest of first panel obs
    C:493earliest of last panel obs
    C:493latest of first panel obs
    C:493latest of last panel obs
    C:493number of observations in
    C:622retrieve current default
    C:622selection and missing values
    UI:139set sample specification in
    O:581specifying sample object
    UI:145specifying samples in panel workfiles
    UII:1900using sample objects in expressions
    UI:145Samples
SAR(p)
save as new workfile
    UI:64workfile precision and compression
    UI:65Scale rows or columns of matrix
    C:741Scaling
with confidence ellipse
    UI:751with kernel regression fit
    UI:745with orthogonal regression line
    UI:750with regression line fit
    O:371equation data member
    O:39Seasonal
Census X-11 (historical)
    UI:518Second moment matrix
    C:724Seed random number generator
    C:479Select
Selection model
Sensitivity of binary prediction
    UII:1237Seqiuence
Sequential breakpoint
Sequential LR tests
    C:153Serial correlation
multivariate VAR LM test
    O:911Serial correlation test
auto-updating and databases
    UI:215convert to matrix (keep NAs)
    C:746extract observation
    C:621fill (background) color for cells
    O:649frequency conversion default method
    O:647text color for cells
    O:657using expressions in place of
    UI:201setattr
    O:14,
    O:27,
    O:171,
    O:238,
    0:261,
    O:314,
    O:383,
    O:415,
    O:430,
    O:462,
    O:500,
    O:541,
    O:570,
    O:581,
    O:586,
    O:647,
    O:721,
    O:750,
    O:763,
    O:769,
    O:797,
    O:837,
    O:860,
    O:886,
    0:894,
    O:901,
    O:954,
    O:984 Shadowing of object names
    UI:350Shape
Shapefile
sheet
Sign
matrix element by element
    C:743Signal variables
Simple switching
@sin C:592, C:618
Sine C:592, C:618
Singular matrix
@skew C:577, C:619
by category C:588, C:619
moving C:583, C:585, C:613, C:614
@skewsby C:588, C:619
Slope equality test
    O:159Slope equality test (quantile regression)
    UII:1480Smooth transition regression
Smoothing
Snapshots
Solve
Source
field in database query
    UI:347Spawn process within EViews
    C:496Spearman covariance
Spearman rank correlation
    UI:600Spearman rank covariance
Spearman rank-order
Special functions C:589
Specification
Specification test
Specification view
Specificity of binary prediction
    UII:1237add objects by command
    C:70declare spool object
    O:723display name by command
    C:72horizontal indentation
    O:711naming objects by command
    C:72show objects in spool
    O:723table and text display mode
    O:723vertical indentation
    O:725Spreadsheet
Spreadsheet view
@sqrt C:570, C:619
sqrt C:570, C:619
Square root C:570, C:619
Squared multiple correlation
    O:242append specification line
    O:733coefficient covariance
    O:735display signal graphs
    O:750make Kalman filter from
    O:741specification display
    O:755Stack
sym matrix by lower column triangle
    C:755Standard deviation
    UI:427, C:577, C:584, C:614, C:619by category C:588, C:619
cumulative C:579, C:580, C:607
moving C:582, C:584, C:613, C:614
row-wise C:586, C:618
Standard error
retrieve from equation
    O:39retrieve from system
    O:806Standard errors
population
 C:577, C:619,
    C:745Start
    UI:346field in workfile details
    UI:52user defined optimization 1:246
final one-step ahead predictions
    O:752Statistical distribution functions C:592
Statistics
compute for subgroups
    O:666stats
@stdev C:577, C:619
@stdevp C:577
@stdevpsby C:588, C:619
@stdevs C:577, C:619
@stdevsby C:588, C:619
@stdevssby C:588, C:619
@stdize C:577, C:619,
    C:744 @stdizep C:577, C:619,
    C:745 Stochastic equations
as replacement variable
    C:134assign to table cell
    C:58convert date string to observation
    C:90,
    C:91convert date value into
    C:650convert date value to string
    C:106convert from a number
    C:661convert into date value
    C:651convert number to string
    C:89current date as a string
    C:91display view of string
    O:764insert string into another string
    C:85,
    C:652relational comparison
    C:79relational comparisons with empty strings
    C:81replace portion of a string with new string
    C:86,
    C:659substring from location
    C:657test for inequality
    C:657test two strings for equality
    C:83test two strings for inequality
    C:83trim spaces from left end
    C:656trim spaces from right end
    C:660String list
Structural change
optimization 1:243
Subtitle
Subtraction operator (-)
    C:274Sum C:577, C:619
cumulative C:578, C:580, C:607
moving C:581, C:583, C:614
@sum C:577, C:619
Sum of squared residuals
Sum of squares C:577, C:619
cumulative C:579, C:581, C:607
moving C:583, C:585, C:614
row-wise C:587, C:618
Summary statistics
@sumsby C:588, C:619
@sumsq C:577, C:619
@sumsqby C:588, C:619
estimating by command
    O:838create from string list
    C:90make from text object
    O:886transition probabilities
    O:945SwitchingVAR
switching intercept likelihood
    UI:1725create from lower triangle of square matrix
    C:724create from scalar function
    C:721create square matrix from
    C:719descriptive statistics
    O:801scale rows and columns
    C:741Symmetric matrix
Symmetrically trimmed residuals
    UII:1261append specification line
    O:809coefficient covariance
    O:817estimation covariance
    O:821full information maximum likelihood
    UII:1592
